Ir para o conteúdo principal
2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement
O que você precisa
  1. 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement, Camera: passo 1, imagem 1 %32 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement, Camera: passo 1, imagem 2 %32 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement, Camera: passo 1, imagem 3 %32
    • Mount the new camera in the space provided.
    • The camera routes through the bumper of the car and not the license plate.
  2. 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: passo 2, imagem 1 %32 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: passo 2, imagem 2 %32 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: passo 2, imagem 3 %32
    • Run the new wires through the holes provided, and cover with electrical tape.
    • The new cords will simply connect where the faulty wires were removed.
  3. 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: passo 3, imagem 1 %32 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: passo 3, imagem 2 %32 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: passo 3, imagem 3 %32
    • Coordinate the colored wires to keep the repair simple. Match the new wires to the existing wires through the splitter. Use a wire splitter to expose the wire.
    • Then simply connect the wires to the wires for reverse light.
  4. 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: passo 4, imagem 1 %32
    • The green wire is the camera connection or positive wire and the black is the ground.
    • This line should already be connected correctly because you should have only switched wires that connected to the camera.
  5. 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: passo 5, imagem 1 %32
    • Make sure that the reverse light is working properly when the car is in reverse.
  6. 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: passo 6, imagem 1 %32
    • Make sure the display is clear and working properly.
Conclusão
2 comentários
The photos you show in steps 2 & 3 - is that the trunk only?
jrselinger24 - Responder
Hello. I am trying to replace my camera. But not sure how to remove it or where to buy a replacement.
Jonathan Anderson - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 42
Últimos 30 dias: 202
Duração total: 13,213
