Introdução
Die Anleitung zeigt dir wie du deine Schlüsselbatterie eines Ford Escape 2013-2017 austauscht. Diese leichte Anleitung zeigt dir Schritt für Schritt den Austausch der Batterie. Man benötigt lediglich die Ersatzbatterie. Der ganze Prozess dauert nur wenige Minuten.
O que você precisa
Den Knopf für die Schlüsselfreigabe verschieben.
Den Metallschlüssel in die Einkerbung auf der linken Seite drücken. Der Schlüssel sollte mit dem Ford Logo nach oben zeigen
Die alte Batterie mit dem Metallschlüssel herausholen
I cannot get the back cover off
See my new comment above.
Die neue Batterie mit "+" nach unten und "-" nach oben einlegen.
Um den Schlüssel wieder zusammen zu setzen, einfach die Rückschale wieder auf den Schlüssel drücken.
36 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
100%
Paku83 está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
16 comentários
Good job. The training aid was clear and lacked nothing. Even had the battery type and a buy function which is a nice touch.
Excellent guide, Thanks for the details
Thanks for the help! Glad I just happened to have a battery and easy to follow instructions.
Easy Cheesy Lemon Squeezy! Thanks for the assist!
Nice tutorial! Here’s a good link if you have other Escape year models: https://fobbattery.com/vehicles/ford/esc...
Thank you so so much! I have a 2014 ford escape and at the worst time ever, it decided to alert me my fob battery was low. (C’mon life!) Worst time ever: 2 ER visits in a month and my hands are numb and tingling and difficult to use! I just completed your excellent guide and the task is DONE and I don’t have to bother my husband! I buy my button cell batts on ebay in bulk….great prices there. Thank you so much!! If I can do it with my issues, anyone can!
I’m glad I found this help. I would not have realized to remove the metal key first. Thanks.
The photo and description in steps 3 and 4 are misleading. Prying the notch as shown breaks the back cover sub assembly (Ford logo) instead of causing the back cover sub assembly to detach from the main fob body.
I found it easier to use my fingernail to pry around the joint between the back cover sub assembly and the main body to open the fob.
Once battery is replaced and the fob is closed, is there any (re)programming that needs to occur to sync the fob with the car?
Easy Peasy, Thank you!
For some reason I can’t get the cover to snap back together? The little “unlock button” you slide down to take apart the remote is down and won’t slide up to lock it together?
