Ir para o conteúdo principal
2013-2017 Ford Escape Schlüsselbatterie ersetzen
O que você precisa
  1. 2013-2017 Ford Escape Schlüsselbatterie ersetzen, 2013-2017 Ford Escape Schlüsselbatterie: passo 1, imagem 1 %32
    • Den Knopf für die Schlüsselfreigabe verschieben.
  2. 2013-2017 Ford Escape Schlüsselbatterie ersetzen: passo 2, imagem 1 %32
    • Den Metallschlüssel aus dem Gehäuse ziehen
  3. 2013-2017 Ford Escape Schlüsselbatterie ersetzen: passo 3, imagem 1 %32
    • Den Metallschlüssel in die Einkerbung auf der linken Seite drücken. Der Schlüssel sollte mit dem Ford Logo nach oben zeigen
  4. 2013-2017 Ford Escape Schlüsselbatterie ersetzen: passo 4, imagem 1 %32 2013-2017 Ford Escape Schlüsselbatterie ersetzen: passo 4, imagem 2 %32
    • Vorsichtig die Rückschale des Schlüssels abheben
  5. 2013-2017 Ford Escape Schlüsselbatterie ersetzen: passo 5, imagem 1 %32 2013-2017 Ford Escape Schlüsselbatterie ersetzen: passo 5, imagem 2 %32
    • Die alte Batterie mit dem Metallschlüssel herausholen
  6. 2013-2017 Ford Escape Schlüsselbatterie ersetzen: passo 6, imagem 1 %32
    • Die neue Batterie mit "+" nach unten und "-" nach oben einlegen.
Conclusão
Um den Schlüssel wieder zusammen zu setzen, einfach die Rückschale wieder auf den Schlüssel drücken.
36 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
en de
100%
Paku83 está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
16 comentários
Good job. The training aid was clear and lacked nothing. Even had the battery type and a buy function which is a nice touch.
Colonel nom de guerre - Responder
How can you find a replacement ignition key? I have the fob, but the ignition key is nowhere to be found, didn't notice it missing on our spare from the dealer until recently.
RU 1979 - Responder
You have to pay for the key it doesn't come with it
datingsas -
Excellent guide, Thanks for the details
Mihael Patrick - Responder
Thanks for the help! Glad I just happened to have a battery and easy to follow instructions.
dingdong406 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 30
Últimos 7 dias: 194
Últimos 30 dias: 964
Duração total: 168,961
