Ir para o conteúdo principal
2013-2017 Ford Escape Key Fob Battery Replacement
O que você precisa
  1. 2013-2017 Ford Escape Key Fob Battery  Replacement, 2013-2017 Ford Escape Key Fob Battery: passo 1, imagem 1 %32
    • Slide over the key release switch on the back of the fob.
  2. 2013-2017 Ford Escape Key Fob Battery  Replacement: passo 2, imagem 1 %32
    • Remove the metal ignition key from the fob.
  3. 2013-2017 Ford Escape Key Fob Battery  Replacement: passo 3, imagem 1 %32
    • Insert the ignition key in the notch on the left with the FORD logo facing upward.
  4. 2013-2017 Ford Escape Key Fob Battery  Replacement: passo 4, imagem 1 %32 2013-2017 Ford Escape Key Fob Battery  Replacement: passo 4, imagem 2 %32
    • Gently remove the back cover of the key fob.
  5. 2013-2017 Ford Escape Key Fob Battery  Replacement: passo 5, imagem 1 %32 2013-2017 Ford Escape Key Fob Battery  Replacement: passo 5, imagem 2 %32
    • Remove the old battery using the ignition key.
  6. 2013-2017 Ford Escape Key Fob Battery  Replacement: passo 6, imagem 1 %32
    • Insert the new battery with “+” facing downward and the “-“ facing upward.
Conclusão
To reassemble your device, replace the back cover to the key fob and secure firmly.
36 outras pessoas executaram este guia.
16 comentários
Good job. The training aid was clear and lacked nothing. Even had the battery type and a buy function which is a nice touch.
Colonel nom de guerre - Responder
How can you find a replacement ignition key? I have the fob, but the ignition key is nowhere to be found, didn't notice it missing on our spare from the dealer until recently.
RU 1979 - Responder
You have to pay for the key it doesn't come with it
datingsas -
Excellent guide, Thanks for the details
Mihael Patrick - Responder
Thanks for the help! Glad I just happened to have a battery and easy to follow instructions.
dingdong406 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 38
Últimos 7 dias: 223
Últimos 30 dias: 890
Duração total: 169,693
