Introdução
If your 2018 Jeep Wrangler key FOB only works intermittently, this can cause a problem as the Jeep Wrangler is a push-button start car. This guide will walk you through how to dissemble your key FOB, replace the battery, and reassemble it. Be careful with the internal battery as it could be corroded and needs to be disposed of properly. This guide is simple and can be done quickly instead of paying a high price for a replacement key.
O que você precisa
Use a spudger or opening tool to open the key fob by inserting it into the indent on the side of the fob and prying it up.
Now your key should be working again.
