Ir para o conteúdo principal
2012-Present Toyota Corolla Windshield Wiper Replacement
O que você precisa
  1. 2012-Present Toyota Corolla Windshield Wiper Replacement, Windshield Wiper: passo 1, imagem 1 %32 2012-Present Toyota Corolla Windshield Wiper Replacement, Windshield Wiper: passo 1, imagem 2 %32
    • Lift up the windshield wiper you're replacing.
  2. 2012-Present Toyota Corolla Windshield Wiper Replacement: passo 2, imagem 1 %32 2012-Present Toyota Corolla Windshield Wiper Replacement: passo 2, imagem 2 %32
    • Insert a flathead screwdriver into the locking mechanism of the wiper and gently pry it open.
    • You can use your car keys in case you do not have a screwdriver.
  3. 2012-Present Toyota Corolla Windshield Wiper Replacement: passo 3, imagem 1 %32 2012-Present Toyota Corolla Windshield Wiper Replacement: passo 3, imagem 2 %32
    • Push the wiper blade downwards until it locks into place.
  4. 2012-Present Toyota Corolla Windshield Wiper Replacement: passo 4, imagem 1 %32 2012-Present Toyota Corolla Windshield Wiper Replacement: passo 4, imagem 2 %32
    • Angle the wiper away from you, so that the top is near you while the bottom is farther away.
    • Gently push the blade out of the wiper base.
  5. 2012-Present Toyota Corolla Windshield Wiper Replacement: passo 5, imagem 1 %32 2012-Present Toyota Corolla Windshield Wiper Replacement: passo 5, imagem 2 %32
    • Bring the new wiper blade into the wiper base from the car, aiming it so that the wiper base enters the lock hole.
    • Once the wiper blade is in, hold it from the bottom and push it upwards to secure the hold.
    • Make sure to start with the lock open, and that the blade is facing the same direction as the picture.
  6. 2012-Present Toyota Corolla Windshield Wiper Replacement: passo 6, imagem 1 %32 2012-Present Toyota Corolla Windshield Wiper Replacement: passo 6, imagem 2 %32 2012-Present Toyota Corolla Windshield Wiper Replacement: passo 6, imagem 3 %32
    • Push down the lock with force until it clicks.
  7. 2012-Present Toyota Corolla Windshield Wiper Replacement: passo 7, imagem 1 %32
    • Repeat for the second blade.
    • Your windshield wiper blade replacement is now complete!
Linha de Chegada
Yusuf Gabaire
Membro desde: 07/03/21
157 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 33
Últimos 30 dias: 145
Duração total: 2,891
