Ir para o conteúdo principal
2012-2018 Nissan Versa Note Headlight Bulb Replacement
O que você precisa
  1. 2012-2018 Nissan Versa Note Headlight Bulb Replacement, Headlight Bulb: passo 1, imagem 1 %32 2012-2018 Nissan Versa Note Headlight Bulb Replacement, Headlight Bulb: passo 1, imagem 2 %32
    • Pull the hood lever.
  2. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: passo 2, imagem 1 %32
    • Push the lever underneath the hood to the left.
    • The lever is located in the center underneath the hood.
  3. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: passo 3, imagem 1 %32
    • Pull up the hood.
  4. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: passo 4, imagem 1 %32
    • Insert the support rod into the slot.
    • The stent is located to the right of the hood.
    • The slot is located in the underside of the hood to the right.
  5. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: passo 5, imagem 1 %32 2012-2018 Nissan Versa Note Headlight Bulb Replacement: passo 5, imagem 2 %32
    • Pull out the connector from the bulb.
    • Depending on the make of your vehicle, you may have push the tab on the connector that reads "push" before pulling out the connector.
  6. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: passo 6, imagem 1 %32
    • Twist the plastic ring out from the bulb.
  7. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: passo 7, imagem 1 %32 2012-2018 Nissan Versa Note Headlight Bulb Replacement: passo 7, imagem 2 %32
    • Pull out the old bulb.
    • High pressure halogen gas is sealed inside the halogen bulb. The bulb may break if the glass envelope is scratched or the bulb is dropped.
    • When handling the bulb, do not touch the glass envelope.
  8. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: passo 8, imagem 1 %32 2012-2018 Nissan Versa Note Headlight Bulb Replacement: passo 8, imagem 2 %32
    • Insert the replacement bulb.
  9. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: passo 9, imagem 1 %32
    • Twist the plastic ring back onto the bulb.
  10. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: passo 10, imagem 1 %32 2012-2018 Nissan Versa Note Headlight Bulb Replacement: passo 10, imagem 2 %32
    • Insert the connector into the bulb.
Linha de Chegada
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 56
Últimos 30 dias: 271
Duração total: 12,284
