Introdução
Use this guide to replace the brake light bulb on the 2012 - 2018 Hyundai Santa Fe Sport.
The brake lights are something that frequently needs replacing compared to other parts and it is important to make sure your brake lights are functioning properly. It will become dangerous to drive around in a car with no brake lights.
There are many other light bulbs to be used as brake lights available, but the one I recommend is the Sylvia 2357 long life mini bulb.
O que você precisa
Remove the black plastic cover located on the inner side taillight by using a #2 flat head screwdriver.
You have now completed the guide, to replace the brake bulb on your 2012 - 2018 Hyundai Santa Fe Sport.
5 outras pessoas executaram este guia.
2 comentários
Follow these steps and you can't go wrong. Nicely done.
