Ir para o conteúdo principal
2011 Mazda 3 Car Speaker Replacement
O que você precisa
  1. 2011 Mazda 3 Car Speaker Replacement, 2011 Mazda 3 Car Speaker: passo 1, imagem 1 %32 2011 Mazda 3 Car Speaker Replacement, 2011 Mazda 3 Car Speaker: passo 1, imagem 2 %32 2011 Mazda 3 Car Speaker Replacement, 2011 Mazda 3 Car Speaker: passo 1, imagem 3 %32
    • Pry the door handle cover upwards using a flathead screwdriver.
    • Remove the cover to expose the screw.
  2. 2011 Mazda 3 Car Speaker Replacement: passo 2, imagem 1 %32 2011 Mazda 3 Car Speaker Replacement: passo 2, imagem 2 %32
    • Pull the door handle towards you.
    • Insert a small flathead screwdriver between the lock and the plate.
    • Pry the plate off by applying leverage away from the lock, exposing the second screw.
  3. 2011 Mazda 3 Car Speaker Replacement: passo 3, imagem 1 %32 2011 Mazda 3 Car Speaker Replacement: passo 3, imagem 2 %32
    • Remove both screws with a Phillips #1 screwdriver.
    • The screws are 12mm Phillip's head. Part number (9986-50-516S).
  4. 2011 Mazda 3 Car Speaker Replacement: passo 4, imagem 1 %32
    • Pry the door cover away from the frame using a heavy-duty spudger.
    • The door cover will not be removed entirely in this step.
    • Prying the door off takes substantial force; moving around the door's perimeter will help unhook the clips that line the panel.
  5. 2011 Mazda 3 Car Speaker Replacement: passo 5, imagem 1 %32 2011 Mazda 3 Car Speaker Replacement: passo 5, imagem 2 %32
    • Push the switch panel out from the inside of the door cover.
    • Ensure the car is off before proceeding.
    • Remove the wires connected to the panel by pressing the clips and pulling them outward.
    • Remove the door cover.
  6. 2011 Mazda 3 Car Speaker Replacement: passo 6, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove the four screws that secure the door speaker.
    • The screws are 10mm Phillip's head. Part number (9984-50-616).
  7. 2011 Mazda 3 Car Speaker Replacement: passo 7, imagem 1 %32
    • Remove the wires connecting the speaker by pressing the clip and pulling it outward.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 18
Últimos 30 dias: 84
Duração total: 2,376
