Ir para o conteúdo principal
2011 Ford Focus Air Conditioning Refrigerant Replacement
O que você precisa
  1. 2011 Ford Focus Air Conditioning  Refrigerant Replacement, Air Conditioning Refrigerant: passo 1, imagem 1 %32 2011 Ford Focus Air Conditioning  Refrigerant Replacement, Air Conditioning Refrigerant: passo 1, imagem 2 %32 2011 Ford Focus Air Conditioning  Refrigerant Replacement, Air Conditioning Refrigerant: passo 1, imagem 3 %32
    • Turn the car on and the A/C to the maximum.
  2. 2011 Ford Focus Air Conditioning  Refrigerant Replacement: passo 2, imagem 1 %32
    • Open your car's hood.
  3. 2011 Ford Focus Air Conditioning  Refrigerant Replacement: passo 3, imagem 1 %32 2011 Ford Focus Air Conditioning  Refrigerant Replacement: passo 3, imagem 2 %32
    • Locate the low-pressure charging port.
  4. 2011 Ford Focus Air Conditioning  Refrigerant Replacement: passo 4, imagem 1 %32
    • Remove the cap by turning it counter-clockwise.
  5. 2011 Ford Focus Air Conditioning  Refrigerant Replacement: passo 5, imagem 1 %32 2011 Ford Focus Air Conditioning  Refrigerant Replacement: passo 5, imagem 2 %32
    • Connect the nozzle and hold the canister at a 3 o'clock angle.
    • Warning: Keep an eye on the PSI level. It should stay between 30 and 50, as going beyond 50 psi could cause the car's compressor to become damaged.
    • Lock and remove the canister if it is around 40 to prevent it from going to 50 psi.
    • Finally, start up the car. If the air conditioning is cooler, you'll know that it works!
Linha de Chegada
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 61
Últimos 30 dias: 219
Ao todo: 9,969
