Ir para o conteúdo principal
2011-2013 Scion tC Radio Head Unit Replacement
O que você precisa
  1. 2011-2013 Scion tC Radio Head Unit Replacement, Radio Head Unit: passo 1, imagem 1 %32 2011-2013 Scion tC Radio Head Unit Replacement, Radio Head Unit: passo 1, imagem 2 %32
    • Remove the dashboard panel around the radio head by pulling on the bottom of the unit.
  2. 2011-2013 Scion tC Radio Head Unit Replacement: passo 2, imagem 1 %32 2011-2013 Scion tC Radio Head Unit Replacement: passo 2, imagem 2 %32
    • Remove the wire header connected to the panel by pressing inward on the tabs.
  3. 2011-2013 Scion tC Radio Head Unit Replacement: passo 3, imagem 1 %32
    • Remove the four #2 12mm screws securing the head unit in the housing
  4. 2011-2013 Scion tC Radio Head Unit Replacement: passo 4, imagem 1 %32 2011-2013 Scion tC Radio Head Unit Replacement: passo 4, imagem 2 %32
    • Remove each bundle of wires that is connected to the back of the head unit.
  5. 2011-2013 Scion tC Radio Head Unit Replacement: passo 5, imagem 1 %32 2011-2013 Scion tC Radio Head Unit Replacement: passo 5, imagem 2 %32
    • Locate the metal brackets on the side of the head unit.
    • Use a Philips head screwdriver, remove the three #2 25mm screws from both support brackets on the side of the head unit
  6. 2011-2013 Scion tC Radio Head Unit Replacement: passo 6, imagem 1 %32
    • Screw the support brackets to the new radio head unit
    • Note that the brackets are unique to the car. They will not come with your new head unit.
Conclusão
Dylan Smith
Membro desde: 05/01/15
143 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 8-2, Regan Spring 2015 Membro de Cal Poly, Team 8-2, Regan Spring 2015
CPSU-REGAN-S15S8G2
Membros da 5
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 25
Duração total: 7,543
