Ir para o conteúdo principal
2011-2013 Scion tC Front Dome Light Replacement
O que você precisa
  1. 2011-2013 Scion tC Front Dome Light Replacement, Front Dome Light: passo 1, imagem 1 %32
    • Remove the plastic covering of the lights by pulling it down quickly from the windshield side.
  2. 2011-2013 Scion tC Front Dome Light Replacement: passo 2, imagem 1 %32
    • Disconnect the plastic header from system by pressing inward on the side tabs.
  3. 2011-2013 Scion tC Front Dome Light Replacement: passo 3, imagem 1 %32 2011-2013 Scion tC Front Dome Light Replacement: passo 3, imagem 2 %32
    • Turn blue knobs counter clockwise and pull to remove bulb housing.
  4. 2011-2013 Scion tC Front Dome Light Replacement: passo 4, imagem 1 %32 2011-2013 Scion tC Front Dome Light Replacement: passo 4, imagem 2 %32
    • Pull burnt bulb out of knob/housing.
    • When inserting the replacement, take note of the direction and polarity of the unit.
Conclusão
To reassemble the dome, follow these instructions in reverse order.
Uma outra pessoa concluiu este guia.
Nick d'Alencon
Membro desde: 05/01/15
346 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 8-2, Regan Spring 2015 Membro de Cal Poly, Team 8-2, Regan Spring 2015
CPSU-REGAN-S15S8G2
Membros da 5
Autoria de 7 guias
Um comentário
I have been looking for how to remove the dome light assembly for awhile now! I felt that I was going to break the clips. Thanks for the great post!
Robert Killenberger - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 33
Duração total: 3,812
