Ir para o conteúdo principal
2011-2013 Scion tC Car Battery Replacement
O que você precisa
  1. 2011-2013 Scion tC Car Battery Replacement, Car Battery: passo 1, imagem 1 %32
    • Begin by opening the hood of the car and locating the battery on the front of the driver side in the engine compartment
  2. 2011-2013 Scion tC Car Battery Replacement: passo 2, imagem 1 %32
    • Using a socket wrench, loosen the 2 (5/16 inch) nuts on the top of the battery support bracket
    • Remove the bracket by lifting up
  3. 2011-2013 Scion tC Car Battery Replacement: passo 3, imagem 1 %32
    • After removing the bracket, locate the supporting rod behind the battery
    • The rod is hooked on a hole in the metal behind the battery. Unhook the rod and remove it
  4. 2011-2013 Scion tC Car Battery Replacement: passo 4, imagem 1 %32 2011-2013 Scion tC Car Battery Replacement: passo 4, imagem 2 %32
    • Start with the negative terminal of the battery
    • Loosen the nut on the negative terminal with a 10mm socket wrench
    • Remove the wire by slightly twisting and pulling up
  5. 2011-2013 Scion tC Car Battery Replacement: passo 5, imagem 1 %32 2011-2013 Scion tC Car Battery Replacement: passo 5, imagem 2 %32
    • Remove the cap from the positive terminal of the battery
    • Using a 10mm socket wrench, loosen the nut on the positive terminal
    • Remove the wire from the positive terminal by slightly twisting and pulling up
    • Remove the battery by lifting it out of the engine compartment
Conclusão
Uma outra pessoa concluiu este guia.
Travis Michael
Membro desde: 05/08/15
140 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 8-2, Regan Spring 2015 Membro de Cal Poly, Team 8-2, Regan Spring 2015
CPSU-REGAN-S15S8G2
Membros da 5
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 27
Duração total: 10,816
