Ir para o conteúdo principal
2010-Present Subaru Legacy Rear Door Reassembly
  1. 2010-Present Subaru Legacy Rear Door Reassembly, 2010-Present Subaru Legacy Rear Door Reassembly: passo 1, imagem 1 %32 2010-Present Subaru Legacy Rear Door Reassembly, 2010-Present Subaru Legacy Rear Door Reassembly: passo 1, imagem 2 %32 2010-Present Subaru Legacy Rear Door Reassembly, 2010-Present Subaru Legacy Rear Door Reassembly: passo 1, imagem 3 %32
    • Insert the metal ball into the plastic door pull handle assembly.
    • With the ball inserted, route the steel cable through the assembly and align the black plastic notch on the cable with the plastic notch on the door pull handle assembly.
    • Press the cable notch into the door pull handle notch and snap it into place.
  2. 2010-Present Subaru Legacy Rear Door Reassembly: passo 2, imagem 1 %32
    • Hold the door lock in the "unlocked" position with your thumb. This will make it easier to insert the metal ball into the door lock assembly.
  3. 2010-Present Subaru Legacy Rear Door Reassembly: passo 3, imagem 1 %32 2010-Present Subaru Legacy Rear Door Reassembly: passo 3, imagem 2 %32
    • Insert the metal ball into the plastic door lock assembly.
    • With the ball inserted, route the steel cable through the assembly and align the blue plastic notch on the cable with the plastic notch on the door lock assembly.
    • Press the cable notch into the door lock notch and snap it into place.
Conclusão
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Ao todo: 740
