Ir para o conteúdo principal
2010 Jeep Liberty Headlight Bulb Replacement
O que você precisa
  1. 2010 Jeep Liberty Headlight Bulb Replacement, Headlight Bulb: passo 1, imagem 1 %32
    • Pop the hood of your vehicle by pulling the lever near the bottom of the driver's side door.
    • Slide your hands under the unlatched hood to find the second lever. Push this lever to the right and lift the hood.
    • Be sure to use the hood prop to keep the hood from falling while you're underneath it.
  2. 2010 Jeep Liberty Headlight Bulb Replacement: passo 2, imagem 1 %32 2010 Jeep Liberty Headlight Bulb Replacement: passo 2, imagem 2 %32 2010 Jeep Liberty Headlight Bulb Replacement: passo 2, imagem 3 %32
    • Identify the bulb socket, located behind the headlight.
    • Rotate the base of the bulb counter-clockwise to remove it from the socket.
    • Remove the bulb from the green base by pulling the two apart.
  3. 2010 Jeep Liberty Headlight Bulb Replacement: passo 3, imagem 1 %32 2010 Jeep Liberty Headlight Bulb Replacement: passo 3, imagem 2 %32 2010 Jeep Liberty Headlight Bulb Replacement: passo 3, imagem 3 %32
    • Insert the new bulb into the green base.
    • Be sure not to touch the glass with your fingers. If you do, wipe the bulb down with a soft cloth and some rubbing alcohol. Oils left behind from your fingers can shorten the life of the bulb.
    • Rotate clockwise to lock the bulb assembly into the socket.
  4. 2010 Jeep Liberty Headlight Bulb Replacement: passo 4, imagem 1 %32
    • Turn on headlights to ensure the new bulb is working properly.
    • You will want to check that your headlights are aligned on both sides. Adjust as needed.
Conclusão
Congratulations! You have a shiny new headlight.
8 outras pessoas executaram este guia.
Ryan Griffin
Membro desde: 01/19/16
245 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 39
Duração total: 8,933
