Introdução
The following guide will walk through steps necessary to replace headlights on a 2010 Chevrolet Aveo and all similar model years. You may find it necessary to complete this replacement if you have noticed your headlight dimming after many years of use. This guide will help to replace these dim headlights so you remain safe on the road. This replacement is accomplished by removing the headlight housing from the vehicle for ease of access.
O que você precisa
Pull the hood release lever underneath the steering wheel to release hood lock.
Repeat steps 3 through 9 for other headlight. Ensure proper working order upon completion.
4 outras pessoas executaram este guia.
