Introdução
Headlights are one of the most important parts of a car when it comes to the safety of drivers. When a headlight goes out, it is not only an inconvenience, but also a danger to all drivers on the road at the time. Luckily, however, if it is simply a bulb that has gone out, it is a simple and quick replacement. In this guide, we are going to show you step-by-step how to efficiently and quickly replace the headlight bulb of a 2010-2014 model Ford Mustang. Follow along with us and we will have you driving safely again shortly!
O que você precisa
To reassemble your device, follow these instructions in reverse order. Once reassembled, test the new bulb to ensure that is safe to drive with. Good luck and we hope you have no further problems!
