Ir para o conteúdo principal
2010-2014 Ford Mustang Air Filter Replacement
  1. 2010-2014 Ford Mustang Air Filter Replacement, Air Filter: passo 1, imagem 1 %32 2010-2014 Ford Mustang Air Filter Replacement, Air Filter: passo 1, imagem 2 %32
    • Make sure the vehicle is off before proceeding. Working under the cars hood can lead to burns if the car is still hot. Be careful!
    • Open the hood by pulling on the lever by the driver's feet.
    • Push upward on the latch under the center of the hood to unlock it.
  2. 2010-2014 Ford Mustang Air Filter Replacement: passo 2, imagem 1 %32
    • Locate the Air Box
  3. 2010-2014 Ford Mustang Air Filter Replacement: passo 3, imagem 1 %32 2010-2014 Ford Mustang Air Filter Replacement: passo 3, imagem 2 %32 2010-2014 Ford Mustang Air Filter Replacement: passo 3, imagem 3 %32
    • Locate the two latches that keep the air box closed.
    • Push on the latch to open the air box as shown in the picture, and repeat on the second latch.
    • Pull up on the top part of the air box and push it to the front of the car to open.
  4. 2010-2014 Ford Mustang Air Filter Replacement: passo 4, imagem 1 %32 2010-2014 Ford Mustang Air Filter Replacement: passo 4, imagem 2 %32
    • Make note of the orientation of the air filter before removing it.
    • Lift the filter straight up from the triangle corner and remove it.
  5. 2010-2014 Ford Mustang Air Filter Replacement: passo 5, imagem 1 %32 2010-2014 Ford Mustang Air Filter Replacement: passo 5, imagem 2 %32
    • Inspect for debris and dirt.
    • The first filter is dirty but does not need to be cleaned or replaced yet.
    • The second filter is dirty and does need to be cleaned or replaced
    • Do not discard the filter because it may be covered under a warranty.
Conclusão
4 outras pessoas executaram este guia.
Christopher Pell
Membro desde: 09/26/12
251 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 15-45, Forte Fall 2012 Membro de Cal Poly, Team 15-45, Forte Fall 2012
CPSU-FORTE-F12S15G45
Membros da 5
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 36
Duração total: 4,785
