Ir para o conteúdo principal
2010-2014 BMW X6 Tail Light Bulb Replacement
  1. 2010-2014 BMW X6 Tail Light Bulb Replacement, Tail Light Bulb: passo 1, imagem 1 %32
    • Turn off the car and let the car cool down for 5 minutes.
  2. 2010-2014 BMW X6 Tail Light Bulb Replacement: passo 2, imagem 1 %32 2010-2014 BMW X6 Tail Light Bulb Replacement: passo 2, imagem 2 %32
    • Open the trunk using your key in the trunk key slot or by using the button under the CD player.
  3. 2010-2014 BMW X6 Tail Light Bulb Replacement: passo 3, imagem 1 %32 2010-2014 BMW X6 Tail Light Bulb Replacement: passo 3, imagem 2 %32 2010-2014 BMW X6 Tail Light Bulb Replacement: passo 3, imagem 3 %32
    • Remove the small plastic cover along the vertical edge of the trunk entrance by pulling outwards using the handle.
    • Pull outwards till pannel comes off and place down giving access to the inside of the quarter panel.
  4. 2010-2014 BMW X6 Tail Light Bulb Replacement: passo 4, imagem 1 %32 2010-2014 BMW X6 Tail Light Bulb Replacement: passo 4, imagem 2 %32 2010-2014 BMW X6 Tail Light Bulb Replacement: passo 4, imagem 3 %32
    • Grab the light bulb socket and turn it counterclockwise until it can be removed from its hole.
    • Repeat this process for the other light bulb socket.
  5. 2010-2014 BMW X6 Tail Light Bulb Replacement: passo 5, imagem 1 %32
    • Remove the light bulbs from their sockets by gently pulling them away from the connectors.
  6. 2010-2014 BMW X6 Tail Light Bulb Replacement: passo 6, imagem 1 %32 2010-2014 BMW X6 Tail Light Bulb Replacement: passo 6, imagem 2 %32 2010-2014 BMW X6 Tail Light Bulb Replacement: passo 6, imagem 3 %32
    • Place the new bulb in the original hole.
    • Turn clockwise to secure the bulb in place.
  7. 2010-2014 BMW X6 Tail Light Bulb Replacement: passo 7, imagem 1 %32 2010-2014 BMW X6 Tail Light Bulb Replacement: passo 7, imagem 2 %32
    • Place Plastic cover along the bottom of the trunk next to the corresponding hole.
    • Push cover in till it is flush with a vertical wall of the trunk.
  8. 2010-2014 BMW X6 Tail Light Bulb Replacement: passo 8, imagem 1 %32 2010-2014 BMW X6 Tail Light Bulb Replacement: passo 8, imagem 2 %32
    • Close trunk and admire your hard work!
Conclusão
Uma outra pessoa concluiu este guia.
Juan M Perez
Membro desde: 10/05/21
190 Reputação
Autoria de 1 guia
Equipe
Um comentário
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 84
Duração total: 2,221
