Introdução
Has one of your brake lights on your 2010-2015 Subaru Outback stopped working? If so, this guide is designed to walk you through the steps of replacing a brake light bulb saving you a trip to the repair shop.
Working brake lights on your vehicle are important for the safety of drivers behind you and for you as a driver so an accident does not happen. Having working tail lights which includes the brake light is the law and will save you from getting an expensive ticket.
Before beginning, have a friend or family member push on the brake pedal for you to see which side of the vehicle the brake light is not working on. Make sure to turn off the vehicle and remove the key from the ignition prior to beginning.
O que você precisa
Turn off the vehicle and remove the key from the ignition switch to avoid any injury while replacing brake light.
