Ir para o conteúdo principal
2010-2017 Suzuki Swift Front Springs Replacement
O que você precisa
  1. 2010-2017 Suzuki Swift Front Springs Replacement, jack up your car: passo 1, imagem 1 %32 2010-2017 Suzuki Swift Front Springs Replacement, jack up your car: passo 1, imagem 2 %32 2010-2017 Suzuki Swift Front Springs Replacement, jack up your car: passo 1, imagem 3 %32
    • CAUTION: THIS PROCESS IS POTENTIALLY DANGEROUS. Be aware of your surroundings and do not go underneath your vehicle until this step is completed.
    • Make sure the handbrake is on, and the gear is in reverse for manual or park for an automatic transmission car.
    • Follow the safety instructions of the jack stand and jack.
    • Refer to this guide for more detailed information on how to jack up a car.
    • Put the jack under the rear frame hook and jack up the back of the car until the jack stands can be put under the jack supports.
    • Put jack stands under the rear jack supports. Slowly lower the weight of the car onto them by lowering the jack.
    • Put the jack under the front sub frame and jack up the front of the car until the jack stands can be put under the jack supports.
    • Put jack stands under the front jack supports. Slowly lower the weight of the car onto them by lowering the jack.
  2. 2010-2017 Suzuki Swift Front Springs Replacement, remove the tire: passo 2, imagem 1 %32
    • Using the 17mm socket, unbolt the wheel nuts and remove the tire from the hub.
  3. 2010-2017 Suzuki Swift Front Springs Replacement, detach cables: passo 3, imagem 1 %32 2010-2017 Suzuki Swift Front Springs Replacement, detach cables: passo 3, imagem 2 %32 2010-2017 Suzuki Swift Front Springs Replacement, detach cables: passo 3, imagem 3 %32
    • Pull the top sensor attachment from the mount.
    • Use the 12mm to disconnect the brake cable bracket.
    • Unclip the lower sensor attachment from the mount. Use the plyers to compress the locking part and pull out the clip.
  4. 2010-2017 Suzuki Swift Front Springs Replacement, disconnect stabilizer bar link: passo 4, imagem 1 %32 2010-2017 Suzuki Swift Front Springs Replacement, disconnect stabilizer bar link: passo 4, imagem 2 %32
    • Use the 5mm hex to hold the bolt in place, while loosing the nut with the 14mm wrench.
    • Pull out the stabilizer bar link from the strut assembly mount.
  5. 2010-2017 Suzuki Swift Front Springs Replacement, disconnect bottom strut assembly: passo 5, imagem 1 %32 2010-2017 Suzuki Swift Front Springs Replacement, disconnect bottom strut assembly: passo 5, imagem 2 %32 2010-2017 Suzuki Swift Front Springs Replacement, disconnect bottom strut assembly: passo 5, imagem 3 %32
    • Put the jack under the wheel arm and let the jack bear the weight of the arm but not lift the arm.
    • Using the 17mm socket, unscrew the nuts from the strut bracket bolts.
    • Use the punch and hammer to punch out the bolts.
  6. 2010-2017 Suzuki Swift Front Springs Replacement, remove strut assembly: passo 6, imagem 1 %32 2010-2017 Suzuki Swift Front Springs Replacement, remove strut assembly: passo 6, imagem 2 %32 2010-2017 Suzuki Swift Front Springs Replacement, remove strut assembly: passo 6, imagem 3 %32
    • Lower the jack and pull the wheel arm from the bottom strut assembly.
    • Open the hood and remove the plastic cap protecting the upper strut mount.
    • Use the 6mm hex to hold the bolt in place, while loosing the nut with the 17mm wrench. When freeing the nut, hold the strut assembly to prevent it from falling.
    • Remove the strut assembly from the wheel-well while ensuring the cables are not damaged.
  7. 2010-2017 Suzuki Swift Front Springs Replacement, remove top from strut assembly: passo 7, imagem 1 %32 2010-2017 Suzuki Swift Front Springs Replacement, remove top from strut assembly: passo 7, imagem 2 %32 2010-2017 Suzuki Swift Front Springs Replacement, remove top from strut assembly: passo 7, imagem 3 %32
    • Use the coil spring compressors to release the tension on the strut assembly head.
    • Use the vise to hold the bottom part of the assembly. Wrap it with some cloth to prevent damage from the grips.
    • Use the 6mm hex to hold the bolt in place, while loosing the nut with the 19mm wrench.
    • Release the strut assembly from the vise and take off all parts from the top and arrange them by order.
  8. 2010-2017 Suzuki Swift Front Springs Replacement, replace spring: passo 8, imagem 1 %32 2010-2017 Suzuki Swift Front Springs Replacement, replace spring: passo 8, imagem 2 %32 2010-2017 Suzuki Swift Front Springs Replacement, replace spring: passo 8, imagem 3 %32
    • You can now take the spring off the strut assembly, together with the dust sleeve.
    • Depending on the height of the replacement spring, you might need to compress it with the coil spring compressors before installation.
    • Put the strut assembly back into the vise.
    • Install the replacement spring together with the dust sleeve. Make sure the bottom of the spring fits in the mount indentation. Don't try to attach the bottom part of the sleeve at this point.
    • Put back the top parts in reverse order and use the 6mm hex and 19mm wrench to tighten the bolt to 50 N·m.
    • Wrap the dust sleeve bottom around the mounts.
  9. 2010-2017 Suzuki Swift Front Springs Replacement, insert strut assembly: passo 9, imagem 1 %32 2010-2017 Suzuki Swift Front Springs Replacement, insert strut assembly: passo 9, imagem 2 %32 2010-2017 Suzuki Swift Front Springs Replacement, insert strut assembly: passo 9, imagem 3 %32
    • Carefully put the strut back and while holding the bottom part, screw back the bolt.
    • Using the 6mm hex and 17mm wrench, tighten to 50 N·m and enclose with the plastic cover.
    • Push against the wheel hub to align the wheel arm with the strut bracket and insert the strut bracket bolts.
    • Apply thread locker and screw the bolts back on, tighten to 90 N·m.
  10. 2010-2017 Suzuki Swift Front Springs Replacement, attach the rest: passo 10, imagem 1 %32 2010-2017 Suzuki Swift Front Springs Replacement, attach the rest: passo 10, imagem 2 %32 2010-2017 Suzuki Swift Front Springs Replacement, attach the rest: passo 10, imagem 3 %32
    • Connect the stabilizer bar link. Tighten to 50 N·m.
    • Bolt the brake cable bracket back on to the strut assembly. Tighten to 25 N·m.
    • Attach the sensor cable to the mounts on the strut assembly.
  11. 2010-2017 Suzuki Swift Front Springs Replacement, attach tire: passo 11, imagem 1 %32
    • Place the tire flat against the wheel hub and make sure the hub holes line up with the rim holes.
    • With the 17mm socket, screw the wheelnuts back in. Tighten to 85 N·m.
Conclusão
To replace the other front spring, repeat the process on the other side of the car. When you’re finished, lower the car with the jack.
knipwim
Membro desde: 09/01/18
8.527 Reputação
Autoria de 30 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 31
Últimos 30 dias: 109
Duração total: 2,520
