Ir para o conteúdo principal
2010-2017 Suzuki Swift Engine Air Filter Replacement
O que você precisa
  1. 2010-2017 Suzuki Swift Engine Air Filter Replacement, locate the filter: passo 1, imagem 1 %32 2010-2017 Suzuki Swift Engine Air Filter Replacement, locate the filter: passo 1, imagem 2 %32 2010-2017 Suzuki Swift Engine Air Filter Replacement, locate the filter: passo 1, imagem 3 %32
    • The filter housing is located behind the air intake.
    • Pull both clasps holding the filter housing to the air intake.
    • Push the housing back to see the filter.
  2. 2010-2017 Suzuki Swift Engine Air Filter Replacement, remove old filter: passo 2, imagem 1 %32 2010-2017 Suzuki Swift Engine Air Filter Replacement, remove old filter: passo 2, imagem 2 %32
    • Slide the old filter up and out.
    • Remember the only square corner of the filter is in the left bottom side.
    • Clean the immediate area of the filter housing, to make sure no dirt ends up in the engine.
  3. 2010-2017 Suzuki Swift Engine Air Filter Replacement, add new filter: passo 3, imagem 1 %32
    • With the square corner at the correct position, slide the new filter in.
    • Make sure the filter fits up with the backside of the air intake on all sides.
  4. 2010-2017 Suzuki Swift Engine Air Filter Replacement, close the filter housing: passo 4, imagem 1 %32 2010-2017 Suzuki Swift Engine Air Filter Replacement, close the filter housing: passo 4, imagem 2 %32
    • Underneath the air filter, 2 holes have to line up with plugs on the filter housing.
    • Once the underside is connected correctly, a small plastic protrustion has to line up with a corresponding guide on the air intake.
    • Clip back the 2 clips, and you are done.
Linha de Chegada
Uma outra pessoa concluiu este guia.
knipwim
Membro desde: 09/01/18
8.527 Reputação
Autoria de 30 guias
Um comentário
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 35
Últimos 30 dias: 137
Duração total: 6,345
