Ir para o conteúdo principal
2010-2017 Suzuki Swift Cabin Air Filter Replacement
O que você precisa
  1. 2010-2017 Suzuki Swift Cabin Air Filter Replacement, remove the glovebox: passo 1, imagem 1 %32 2010-2017 Suzuki Swift Cabin Air Filter Replacement, remove the glovebox: passo 1, imagem 2 %32 2010-2017 Suzuki Swift Cabin Air Filter Replacement, remove the glovebox: passo 1, imagem 3 %32
    • The cabin air filter is located behind the glovebox. To access it, the glovebox needs to be removed.
    • After opening, 2 supports on the back of the glovebox prevent the glovebox from falling on the floor.
    • With your hands, push the left support to the right, making sure the rubber band doesn't catch on the frame.
    • If the left support can move freely, pull the glovebox towards you and to the left, to also free the right support.
    • Pull the glovebox towards you to pull the bottom hinges free.
  2. 2010-2017 Suzuki Swift Cabin Air Filter Replacement, replace the filter: passo 2, imagem 1 %32 2010-2017 Suzuki Swift Cabin Air Filter Replacement, replace the filter: passo 2, imagem 2 %32
    • The cabin air filter can be accessed by removing the cover from the filter housing.
    • Get your fingers behind the cover latches and pull the cover toward you, removing the cover.
    • Pull the filter out, and prevent dirt from falling out.
    • Put the new filter in, and make sure to follow the design of your filter manufacturer (air is pulled in from the top).
    • Put the cover back.
  3. 2010-2017 Suzuki Swift Cabin Air Filter Replacement, put back the glovebox: passo 3, imagem 1 %32 2010-2017 Suzuki Swift Cabin Air Filter Replacement, put back the glovebox: passo 3, imagem 2 %32
    • Put the glovebox hinge parts back into the frame hinge parts.
    • Lift the glovebox and push equally on both sides to force the supports back behind the frame.
Linha de Chegada
knipwim
Membro desde: 09/01/18
8.527 Reputação
Autoria de 30 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 42
Últimos 30 dias: 232
Duração total: 6,800
