Introdução
Use this guide to replace a cabin air filter in a 2009 Toyota Camry.
Cabin air filters are made of multi-fiber paper cotton that helps prevent dust, pollen, dirt, and other pollutants from entering the cabin through your A/C and heat vents. Any cabin filter can be used as long as it is for a 2009 Toyota Camry. It is recommended to change an air filter every 12,000-15,000. There is nothing harmful that can happen from replacing the filter. It is an easy fix that can be done in less than 5 minutes.
O que você precisa
