Ir para o conteúdo principal
2009 Subaru Impreza WRX Rear Door Panel Replacement
O que você precisa
  1. 2009 Subaru Impreza WRX Rear Door Panel Replacement, Rear Door Panel: passo 1, imagem 1 %32
    • Pry off the plastic tab inside the rear door handle.
  2. 2009 Subaru Impreza WRX Rear Door Panel Replacement: passo 2, imagem 1 %32
    • Use the Phillips screwdriver to unscrew the 8x3/4" Phillips screw inside the door handle.
  3. 2009 Subaru Impreza WRX Rear Door Panel Replacement: passo 3, imagem 1 %32
    • Use a flathead screwdriver to pry up the plastic tab inside the rear door armrest.
  4. 2009 Subaru Impreza WRX Rear Door Panel Replacement: passo 4, imagem 1 %32
    • Use the Phillips screwdriver to unscrew the 8x3/4" Phillips screw inside the armrest.
  5. 2009 Subaru Impreza WRX Rear Door Panel Replacement: passo 5, imagem 1 %32 2009 Subaru Impreza WRX Rear Door Panel Replacement: passo 5, imagem 2 %32
    • Use flathead to pry off the upper panel located at the top of the rear door panel.
  6. 2009 Subaru Impreza WRX Rear Door Panel Replacement: passo 6, imagem 1 %32 2009 Subaru Impreza WRX Rear Door Panel Replacement: passo 6, imagem 2 %32
    • Use the flathead screwdriver to pry off and remove the panel over the door handle.
  7. 2009 Subaru Impreza WRX Rear Door Panel Replacement: passo 7, imagem 1 %32
    • Remove the bundle of wires from the panel by pressing the tabs on the sides of the large white plastic connector.
  8. 2009 Subaru Impreza WRX Rear Door Panel Replacement: passo 8, imagem 1 %32
    • Use the Phillips screwdriver to unscrew the 8x3/4" screws behind the door handle panel that was just removed.
  9. 2009 Subaru Impreza WRX Rear Door Panel Replacement: passo 9, imagem 1 %32
    • Use the flathead screwdriver to pry off the door panel, starting from the outside edge of the door.
  10. 2009 Subaru Impreza WRX Rear Door Panel Replacement: passo 10, imagem 1 %32
    • Use your hands to pull off and remove the door panel from the frame.
  11. 2009 Subaru Impreza WRX Rear Door Panel Replacement: passo 11, imagem 1 %32
    • Using your hands, remove the two remaining wires connecting the door panel to the frame.
    • The door panel is now completely removed from the frame.
Conclusão
Joseph Coplon
Membro desde: 04/20/15
101 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 8-3, Regan Spring 2015 Membro de Cal Poly, Team 8-3, Regan Spring 2015
CPSU-REGAN-S15S8G3
Membros da 5
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 19
Duração total: 2,452
