Ir para o conteúdo principal
2009 Honda Fit Brake Light Bulb Replacement
O que você precisa
  1. 2009 Honda Fit Brake Light Bulb Replacement, Brake Light Bulb: passo 1, imagem 1 %32
    • Open your trunk to access the brake light panel.
    Pergunte ao FixBot
    Comentar
  2. 2009 Honda Fit Brake Light Bulb Replacement: passo 2, imagem 1 %32 2009 Honda Fit Brake Light Bulb Replacement: passo 2, imagem 2 %32 2009 Honda Fit Brake Light Bulb Replacement: passo 2, imagem 3 %32
    • Use a trim removal tool or your key to pry the panel and gain access to the brake light.
    Pergunte ao FixBot
    Comentar
  3. 2009 Honda Fit Brake Light Bulb Replacement: passo 3, imagem 1 %32 2009 Honda Fit Brake Light Bulb Replacement: passo 3, imagem 2 %32 2009 Honda Fit Brake Light Bulb Replacement: passo 3, imagem 3 %32
    • Rotate the brake light socket clockwise until it unlocks.
    • Pull out the brake light socket.
    • Make sure you are replacing the bottom bulb(brake light) and not the top bulb(tail light).
    Pergunte ao FixBot
    Comentar
  4. 2009 Honda Fit Brake Light Bulb Replacement: passo 4, imagem 1 %32 2009 Honda Fit Brake Light Bulb Replacement: passo 4, imagem 2 %32
    • Pull out the old bulb from brake light socket and insert new bulb.
    • The old bulb can be identified with its dark burnt look.
    • Wear a nitrile glove or something similar to avoid getting oils from your fingers on the glass bulb. The oils and salt on your hands can reduce the life of the bulb and cause it to burn out more quickly.
    Pergunte ao FixBot
    Comentar
  5. 2009 Honda Fit Brake Light Bulb Replacement: passo 5, imagem 1 %32 2009 Honda Fit Brake Light Bulb Replacement: passo 5, imagem 2 %32
    • Insert brake light socket with the new bulb into the housing compartment.
    • Similar to the removal, you have to rotate the socket into a locked position.
    Pergunte ao FixBot
    Comentar
  6. 2009 Honda Fit Brake Light Bulb Replacement: passo 6, imagem 1 %32 2009 Honda Fit Brake Light Bulb Replacement: passo 6, imagem 2 %32 2009 Honda Fit Brake Light Bulb Replacement: passo 6, imagem 3 %32
    • After reassembly, have someone test the brake light so you can see if it works or not.
    • If no one is available to help, reverse towards a wall and park. Press on the brake and look at your side mirrors to check if they light up.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
mchail
Membro desde: 03/05/24
196 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 16
Últimos 30 dias: 121
Ao todo: 2,729
