Ir para o conteúdo principal
2009-2012 Honda Fit Blower Motor and Blower Motor Control Module Replacement Replacement
O que você precisa
  1. 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement, Blower Motor and Blower Motor Control Module Replacement: passo 1, imagem 1 %32 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement, Blower Motor and Blower Motor Control Module Replacement: passo 1, imagem 2 %32 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement, Blower Motor and Blower Motor Control Module Replacement: passo 1, imagem 3 %32
    • Never work on car electronics when the car is running. Disconnect the battery before beginning.
    • Secure the car with the emergency break.
    • Open the glove box.
    • Push the sides to release the glove box.
    Pergunte ao FixBot
    Comentar
  2. 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: passo 2, imagem 1 %32 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: passo 2, imagem 2 %32
    • Unscrew the top screw on the resistor module with a long Phillips screwdriver.
    Pergunte ao FixBot
    Comentar
  3. 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: passo 3, imagem 1 %32 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: passo 3, imagem 2 %32 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: passo 3, imagem 3 %32
    • Find the edges of the bottom cover and pull down to release the two clips.
    • Set bottom cover aside until replacement is completed.
    Pergunte ao FixBot
    Comentar
  4. 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: passo 4, imagem 1 %32 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: passo 4, imagem 2 %32
    • Unscrew the bottom screw with the stubby Philips screwdriver.
    Pergunte ao FixBot
    Comentar
  5. 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: passo 5, imagem 1 %32 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: passo 5, imagem 2 %32
    • Pull the module out of its slot.
    • Push the tab and pull to release the module.
    • Follow these steps in reverse to replace the module.
    • If you are just replacing the control module, refer to step 11 to replace the bottom cover.
    Pergunte ao FixBot
    Comentar
  6. 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: passo 6, imagem 1 %32 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: passo 6, imagem 2 %32 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: passo 6, imagem 3 %32
    • Use a T20 Torx screwdriver to release the screws securing the blower motor.
    Pergunte ao FixBot
    Comentar
  7. 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: passo 7, imagem 1 %32 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: passo 7, imagem 2 %32 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: passo 7, imagem 3 %32
    • Slide the motor out of the slot.
    • The motor is heavy, so take care handling it.
    Pergunte ao FixBot
    Comentar
  8. 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: passo 8, imagem 1 %32 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: passo 8, imagem 2 %32 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: passo 8, imagem 3 %32
    • Squeeze the clip to release the wire.
    Pergunte ao FixBot
    Comentar
  9. 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: passo 9, imagem 1 %32 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: passo 9, imagem 2 %32
    • Attach the clip to the plug.
    • Orient the rectangular point to face the front passenger wheel.
    • Slide the motor into the circular slot so it fits snugly.
    Pergunte ao FixBot
    Comentar
  10. 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: passo 10, imagem 1 %32
    • Replace the three T20 Torx screws.
    Pergunte ao FixBot
    Comentar
  11. 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: passo 11, imagem 1 %32 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: passo 11, imagem 2 %32
    • Find the two hooks to anchor the cover to the back.
    • Place your hands under the two clips on the front and click the clips into place directly under the glove box.
    Pergunte ao FixBot
    Comentar
  12. 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: passo 12, imagem 1 %32 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: passo 12, imagem 2 %32 2009-2012 Honda Fit  Blower Motor and Blower Motor Control Module Replacement Replacement: passo 12, imagem 3 %32
    • Leaving a car engine on in an enclosed space can lead to carbon monoxide poisoning and/or death.
    • Reconnect the battery.
    • Turn the key to the third position to engage the accessory mode.
    • Make sure the AC button below the stereo is on to ensure the Air Conditioning is engaged.
    • Turn the Fan Control dial to each setting. Air should flow normal at each setting.
    Pergunte ao FixBot
    Comentar
Linha de Chegada
Uma outra pessoa concluiu este guia.
Caleb French
Membro desde: 09/24/25
205 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 9
Últimos 7 dias: 58
Últimos 30 dias: 283
Ao todo: 1,357
