Introdução
This isn’t a very difficult task, but you do need to know what you’re doing. You can use a 10 mm socket and socket wrench or the equivalent of such, it doesn’t matter much. You can even just use an adjustable wrench, though it’d be easier if you used the socket wrench. It would also help if you had an extender and a Phillips screwdriver. Be sure to wear gloves too, if you aren’t careful you can shock yourself.
O que você precisa
After everything in this guide is done, all you need to do is take off the previous headlight bulb and put the new one in. Then, be sure to reassemble everything by following these instructions in reverse order. If for some reason this does not solve your issue, be sure to make sure everything is reconnected, including both the battery and headlight bulb. Otherwise, you may be trying to fix something that is not the issue, or only part of said issue.
5 outras pessoas executaram este guia.
