Ir para o conteúdo principal
2009-2015 Suzuki Alto Head Unit Replacement
O que você precisa
  1. 2009-2015 Suzuki Alto Head Unit Replacement, removing the bezels: passo 1, imagem 1 %32 2009-2015 Suzuki Alto Head Unit Replacement, removing the bezels: passo 1, imagem 2 %32 2009-2015 Suzuki Alto Head Unit Replacement, removing the bezels: passo 1, imagem 3 %32
    • Use soft disassemble tools to remove the bezels hiding the screws.
  2. 2009-2015 Suzuki Alto Head Unit Replacement, removing the AC vents: passo 2, imagem 1 %32
    • Pull it like a drawer.
  3. 2009-2015 Suzuki Alto Head Unit Replacement, remove the original head unit: passo 3, imagem 1 %32 2009-2015 Suzuki Alto Head Unit Replacement, remove the original head unit: passo 3, imagem 2 %32 2009-2015 Suzuki Alto Head Unit Replacement, remove the original head unit: passo 3, imagem 3 %32
    • Disconnect the connectors.
  4. 2009-2015 Suzuki Alto Head Unit Replacement, removing the mounting plates: passo 4, imagem 1 %32 2009-2015 Suzuki Alto Head Unit Replacement, removing the mounting plates: passo 4, imagem 2 %32
    • Unscrew mounting plates from original headunit to custom headunit.
  5. 2009-2015 Suzuki Alto Head Unit Replacement, installing the mounting plates: passo 5, imagem 1 %32 2009-2015 Suzuki Alto Head Unit Replacement, installing the mounting plates: passo 5, imagem 2 %32 2009-2015 Suzuki Alto Head Unit Replacement, installing the mounting plates: passo 5, imagem 3 %32
    • Screw the mounting plates on to your custom head unit.
  6. 2009-2015 Suzuki Alto Head Unit Replacement, add the bezel: passo 6, imagem 1 %32 2009-2015 Suzuki Alto Head Unit Replacement, add the bezel: passo 6, imagem 2 %32 2009-2015 Suzuki Alto Head Unit Replacement, add the bezel: passo 6, imagem 3 %32
    • Add the unit's bezel.
  7. 2009-2015 Suzuki Alto Head Unit Replacement, connecting the wires: passo 7, imagem 1 %32 2009-2015 Suzuki Alto Head Unit Replacement, connecting the wires: passo 7, imagem 2 %32
    • You will need an adapter from Suzuki's headunit connection to generic connection.
  8. 2009-2015 Suzuki Alto Head Unit Replacement, installing the headunit: passo 8, imagem 1 %32 2009-2015 Suzuki Alto Head Unit Replacement, installing the headunit: passo 8, imagem 2 %32 2009-2015 Suzuki Alto Head Unit Replacement, installing the headunit: passo 8, imagem 3 %32
    • Return the AC grill, screws and bezels.
Linha de Chegada
18 outras pessoas executaram este guia.
Jossef Harush
Membro desde: 11/26/15
375 Reputação
Autoria de 1 guia
8 comentários
Thanks for this, exactly what ive been looking for. I dont suppose you'd know the type of adapter necessary to connect the suzuki plug to an after market stereo? Thanks again for the guide!
robmatheson72 - Responder
Here is one sold under the type code CT20SZ02. Looks like this type of connector is used in a lot of recent Suzuki models, so they should be available from other stores (using other names).
knipwim -
Absolutely brilliant guide. Thanks. Had to purchase a different harness adaptor for my 14 alto sz3. It says on the packet the harness is for Honda Acc 9/98> but this fits and works 100%. Available from Halfords it is item PC2-68-4. Once again many thanks for the guide.
Bryan Tucker - Responder
Thanks Jossef Harush for such a detailed guide. It really helps me a lot but at last due to some reasons the connection cable tear out and I have to reach out Gomechanic team for the replacement with a genuine wire. Love their service as well as your guide too.
kasmira khandelwal - Responder
Thanks so much for this guide.
We have removed the screws on the head unit but it will not pull out at all, it seems completely stuck. Any suggestions on how to remove it or something we are missing?
James Insalaco - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 60
Últimos 30 dias: 160
Duração total: 16,627
