Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Change the oil in your 2008 or newer Scion xB to keep the engine running strong. Regular oil changes are one of the easiest DIY procedures to prolong engine life.
For years, 3,000 miles was the correct interval to wait between oil changes, but that is no longer the case. Conventional oil in today's engines can easily last over 5,000 miles between changes. Synthetic oils are even more durable, maintaining good engine performance beyond 10,000 miles.
O que você precisa
Loosen the lug nuts on the passenger side front wheel a half turn with a 22 mm wrench or tire iron.
Jack up the front right corner of the car by placing a jack under the long vertical portion of the frame directly behind the wheel well.
Raise the car until the wheel is a couple inches off the ground
Place a jack stand between the two notches in the frame a few inches back from the jack.
Slowly lower the car onto the jack stand.
Grab the yellow handle of the engine oil dipstick at the front of the engine and pull the dipstick out.
Wipe down the dipstick with a rag or towel, reinsert it, then pull it out again to get a an oil level reading.
The oil level should be somewhere between the two holes, which denote the minimum and maximum levels. Add or drain oil as necessary until you have an appropriate level.
Reinstall the dipstick and oil filler cap. Twist the cap clockwise until it is snug.
Use a 22mm tire iron or torque wrench to tighten the lug nuts to 80 ft-lbs. To make sure that you tighten the nuts evenly, work in a star pattern:
Top
Bottom Right
Top Left
Top Right
Bottom Left.
Jack the car up about an inch and remove the jack stand.
Slowly lower the jack and remove it from under the car.
To reset the 'Maintenance Required' light on your dash, turn the ignition to On and press the odometer button until the dash displays Trip A.
Turn the ignition off.
Hold the button and turn the ignition to On.
Continue to hold the button during the countdown and release after the zeros flash across the display.
Before driving away, start the car and let it run for a few minutes to allow the new oil to circulate through the engine. While the engine is running, check underneath the car for any oil leaks. Turn the car off and check the oil level one last time. Add or drain oil as necessary.
Allow 12-24 hours for all of the oil to drain out of the old oil filter.
Take your old oil and filter to a recycling facility. Most auto parts stores and repair shops accept these at no charge to you. In addition, some cities and/or counties have a service where they will collect used oil and filters from your home. For more information, see the American Petroleum Institute's web page on used motor oil collection and recycling.
23 outras pessoas executaram este guia.
8 comentários
i opened the oil cap on top of the engine before draining to help it drain faster. not sure if that helped or not but i saw no reason not to..
Mike,
I changed my wife's 2014 Subaru Forester for the first time and removed the filter first. When I extracted the oil drain plug, the oil gushed out so strong and fast that it overloaded my oil drain container and it overflowed. Since then, I leave the filter on when I change the oil. I think it acted like an air hole poked in the top of a container that reduced the natural restriction when the filter was in place, much like emptying a 1-gallon water jug. If you poke a hole in the top of an old milk jug and up-end it, it will empty much faster; simple physics. I must have forgotten that high-school physics detail when I did that job. I remembered that physics teacher right away, Mike.
Who takes off a wheel to change the oil? Why not just pull the oil filter off from under the car, like everybody else does? Worse case scenario you may need a filter wrench. $6 at Autozone ...
the problem is, the engine guard underneath is in the way. You need to undo 6 bolts and about 6 snap rivets. So to some, the wheel option might be better.
Remove the wheel? Why?
The only tool I need to change my oil is a funnel. To speed things up I installed a QwikValve on the pan and cut off the little plastic flap below the filter since it's useless anyway. So, I slide a drain pan under the car, open the QwikValve, drink a beer while it drains, close the valve, remove and replace the filter (which should only be hand tight), fill with 4.5 qts of oil and I'm finished. 20 minutes and it's done, 10 of those minutes is waiting for the oil to fully drain.
