Introdução
If you notice that your 2008 Volvo S40's headlights are dimming or have gone out completely, then it may be time to replace the headlight bulbs. Over time, the bulbs will wear out and will eventually need to be replaced. Whether it's to replace a worn out bulb or to install a brighter bulb, such as an LED, understanding how to change the headlights in your car is a very important skill that every car owner should know.
This guide will cover how to completely replace the low beam headlight bulbs on a 2008 Volvo S40 to ensure that your vehicle is safe and legal to drive on public roads.
Before beginning, ensure that all of your vehicle's lights are off, the key is removed from the ignition, and the parking brake is engaged.
Open the hood of the car and locate the silver locking pin.
Gently grasp the top of the pin and pull it directly up until it is completely removed from the engine bay.
