Ir para o conteúdo principal
2008 Volkswagen Jetta Radio Replacement
O que você precisa
  1. 2008 Volkswagen Jetta Radio Replacement, Radio: passo 1, imagem 1 %32
    • Starting from the back of the top panel, pry open the top panel with a panel tool.
    • Remove the top panel exposing the under.
    • Be careful when removing the layers as they have very delicate clips holding them together.
    Pergunte ao FixBot
    Comentar
  2. 2008 Volkswagen Jetta Radio Replacement: passo 2, imagem 1 %32 2008 Volkswagen Jetta Radio Replacement: passo 2, imagem 2 %32 2008 Volkswagen Jetta Radio Replacement: passo 2, imagem 3 %32
    • Use the T20 Torx screwdriver to remove the single screw.
    • After screw is removed, pull out the cover.
    Pergunte ao FixBot
    Comentar
  3. 2008 Volkswagen Jetta Radio Replacement: passo 3, imagem 1 %32
    • Within the third layer, remove two more screws using the T20 Torx Screwdriver.
    • Use the panel tool to unclip the three clips on the back then remove the 3rd panel.
    Pergunte ao FixBot
    Comentar
  4. 2008 Volkswagen Jetta Radio Replacement: passo 4, imagem 1 %32 2008 Volkswagen Jetta Radio Replacement: passo 4, imagem 2 %32 2008 Volkswagen Jetta Radio Replacement: passo 4, imagem 3 %32
    • Use the panel tool and slowly loosen up the outer shell by following the crevice outline.
    • Once loosened up remove the upper face layer.
    • When removing this layer there will be a wire connecting the passenger air bag light. Leave that wire alone and carefully place the layer on the dashboard.
    Pergunte ao FixBot
    Comentar
  5. 2008 Volkswagen Jetta Radio Replacement: passo 5, imagem 1 %32 2008 Volkswagen Jetta Radio Replacement: passo 5, imagem 2 %32
    • Remove the two screws using the T20 Torx Screwdriver.
    • Use the panel tool once again to carefully open up the crevices on the bottom cover. Remove the layer.
    Pergunte ao FixBot
    Comentar
  6. 2008 Volkswagen Jetta Radio Replacement: passo 6, imagem 1 %32
    • Use the T20 Torx remove the four screws placing the radio in place.
    • Once the screws are removed carefully pull out the radio to reveal the wires connected on the back.
    Pergunte ao FixBot
    Comentar
  7. 2008 Volkswagen Jetta Radio Replacement: passo 7, imagem 1 %32 2008 Volkswagen Jetta Radio Replacement: passo 7, imagem 2 %32 2008 Volkswagen Jetta Radio Replacement: passo 7, imagem 3 %32
    • There will be two clipped wires on the back of he radio.
    • Push the clips in on the black wires connected to loosen them up and carefully pull out the wire.
    • The second bunch of wires will only require a flip of the lever down on the bottom of the black outer box. Once flipped up remove the whole box to free the radio.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 22
Últimos 30 dias: 81
Ao todo: 5,408
