Ir para o conteúdo principal
2008 Toyota Corolla Battery Replacement
O que você precisa
  1. 2008 Toyota Corolla Battery Replacement, Battery: passo 1, imagem 1 %32 2008 Toyota Corolla Battery Replacement, Battery: passo 1, imagem 2 %32
    • Open the car hood.
    • The battery will be located on the bottom right.
  2. 2008 Toyota Corolla Battery Replacement: passo 2, imagem 1 %32 2008 Toyota Corolla Battery Replacement: passo 2, imagem 2 %32
    • There are two terminals on the battery. The positive terminal is on the left with the red cover. The negative terminal is on the right.
    • Unscrew the bolt to loosen the negative terminal.
    • Remove the negative terminal from the battery.
  3. 2008 Toyota Corolla Battery Replacement: passo 3, imagem 1 %32 2008 Toyota Corolla Battery Replacement: passo 3, imagem 2 %32
    • Take the red cover off the positive terminal.
    • Unscrew the bolt to remove the positive terminal.
    • Loosening the screws of the terminal can be difficult. In the first picture, I used pliers to help loosen up the screw holding the terminal tight.
  4. 2008 Toyota Corolla Battery Replacement: passo 4, imagem 1 %32 2008 Toyota Corolla Battery Replacement: passo 4, imagem 2 %32 2008 Toyota Corolla Battery Replacement: passo 4, imagem 3 %32
    • Disconnect the battery's terminals from the battery, and remove the old battery.
    • Batteries, over time, tend to get dirty. You can mix baking soda with water and use a brush to clean your terminals.
  5. 2008 Toyota Corolla Battery Replacement: passo 5, imagem 1 %32 2008 Toyota Corolla Battery Replacement: passo 5, imagem 2 %32 2008 Toyota Corolla Battery Replacement: passo 5, imagem 3 %32
    • Once everything is clean, you can begin installing your new battery.
    • Install your new battery in the correct space. You will install the negative terminal first, then the positive terminal.
    • Before moving on, make sure each screw on the terminal is tight and secured.
  6. 2008 Toyota Corolla Battery Replacement: passo 6, imagem 1 %32
    • Ensure that every bolt is secured.
    • Start your car and let your car run for a couple of minutes.
Linha de Chegada
4 outras pessoas executaram este guia.
Lair Noriega
Membro desde: 04/04/22
237 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 34
Últimos 30 dias: 181
Duração total: 4,006
