Introdução
This 2008 Honda Pilot was hit by a falling limb which broke its waterproof seal. As a result the tail light assembly now has standing water in it. In order to fix this issue I will be replacing the assembly with a new one purchased online.
If you have a 2008 Honda Pilot, and the tail light assembly is broken, then use this guide to replace the broken assembly with a new one.
The tail light assembly is the part of the vehicle that houses the tail lights. A broken assembly can, over time, become a safety hazard. Without a proper housing it is far more likely that your tail lights will fail. This includes your brake lights and turn signal. Driving without these safety features isn’t safe for you or other drivers.
Before using this guide, find a quality tail light assembly that is made for a 2008 Honda Pilot and have it at the ready. These can be bought for a reasonable price from many online vendors.
O que você precisa
Open the vehicle's trunk to see the two bolts holding the assembly to the body.
Remove the two 8 mm bolts using either a Phillips head screwdriver or socket wrench.
Congratulations! You have successfully completed the guide! Enjoy your new tail light assembly.
Uma outra pessoa concluiu este guia.
