Ir para o conteúdo principal
2008 Honda Fit Inner Door Grip Replacement
  1. 2008 Honda Fit Inner Door Grip Replacement, Inner Door Grip: passo 1, imagem 1 %32
    • Park the car on a level surface and engage the parking brake.
    Pergunte ao FixBot
    Comentar
  2. 2008 Honda Fit Inner Door Grip Replacement: passo 2, imagem 1 %32 2008 Honda Fit Inner Door Grip Replacement: passo 2, imagem 2 %32
    • Open the door to access the interior door panel. Remove any dirt or tape from the door handle.
    • Remove the taped or broken inner door handle from the inner door panel of the car.
    Pergunte ao FixBot
    Comentar
  3. 2008 Honda Fit Inner Door Grip Replacement: passo 3, imagem 1 %32 2008 Honda Fit Inner Door Grip Replacement: passo 3, imagem 2 %32 2008 Honda Fit Inner Door Grip Replacement: passo 3, imagem 3 %32
    • Retrieve the door grip and hook the door grip to the panel by the hook that is attached to the door panel.
    Pergunte ao FixBot
    Comentar
  4. 2008 Honda Fit Inner Door Grip Replacement: passo 4, imagem 1 %32 2008 Honda Fit Inner Door Grip Replacement: passo 4, imagem 2 %32
    • Once the door grip is hooked to the door panel, the door grip will hang.
    Pergunte ao FixBot
    Comentar
  5. 2008 Honda Fit Inner Door Grip Replacement: passo 5, imagem 1 %32 2008 Honda Fit Inner Door Grip Replacement: passo 5, imagem 2 %32 2008 Honda Fit Inner Door Grip Replacement: passo 5, imagem 3 %32
    • Starting with the right side, adjust the door grip to the claw attached to the door panel's right side.
    • Push the door grip gently.
    Pergunte ao FixBot
    Comentar
  6. 2008 Honda Fit Inner Door Grip Replacement: passo 6, imagem 1 %32 2008 Honda Fit Inner Door Grip Replacement: passo 6, imagem 2 %32 2008 Honda Fit Inner Door Grip Replacement: passo 6, imagem 3 %32
    • Push the door grip to the claw attached to the door panel to lock the door grip so it attaches.
    Pergunte ao FixBot
    Comentar
  7. 2008 Honda Fit Inner Door Grip Replacement: passo 7, imagem 1 %32 2008 Honda Fit Inner Door Grip Replacement: passo 7, imagem 2 %32 2008 Honda Fit Inner Door Grip Replacement: passo 7, imagem 3 %32
    • Insert the door grip into the center of the door panel that has two holes.
    • Make sure the centerpiece of the door grip is aligned with the center holes of the door panel for it to attach properly.
    Pergunte ao FixBot
    Comentar
  8. 2008 Honda Fit Inner Door Grip Replacement: passo 8, imagem 1 %32 2008 Honda Fit Inner Door Grip Replacement: passo 8, imagem 2 %32
    • Push the door grip to the claws on the top center of the door panel so it attaches.
    Pergunte ao FixBot
    Comentar
  9. 2008 Honda Fit Inner Door Grip Replacement: passo 9, imagem 1 %32 2008 Honda Fit Inner Door Grip Replacement: passo 9, imagem 2 %32 2008 Honda Fit Inner Door Grip Replacement: passo 9, imagem 3 %32
    • Finally, press the left side of the door grip to the far left of the door panel to align with the door clips so that it holds the left side balancing the right.
    Pergunte ao FixBot
    Comentar
  10. 2008 Honda Fit Inner Door Grip Replacement: passo 10, imagem 1 %32
    • Once each side of the door grip is attached to the door panel the inner door grip/handle is fixed.
    Pergunte ao FixBot
    Comentar
Linha de Chegada
Uma outra pessoa concluiu este guia.
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 22
Últimos 30 dias: 94
Ao todo: 3,102
