Ir para o conteúdo principal
2008-2012 Honda Accord Interior Lights Replacement
O que você precisa
  1. 2008-2012 Honda Accord Interior Lights Replacement, Interior Light: passo 1, imagem 1 %32 2008-2012 Honda Accord Interior Lights Replacement, Interior Light: passo 1, imagem 2 %32
    • Acquire replacement car dome light and a 1/4" flathead screwdriver.
  2. 2008-2012 Honda Accord Interior Lights Replacement: passo 2, imagem 1 %32 2008-2012 Honda Accord Interior Lights Replacement: passo 2, imagem 2 %32
    • Identify the broken light(s). Turn the light switch on and off to find the broken light.
  3. 2008-2012 Honda Accord Interior Lights Replacement: passo 3, imagem 1 %32 2008-2012 Honda Accord Interior Lights Replacement: passo 3, imagem 2 %32
    • Use the screwdriver to carefully remove the plastic cover.
    • Insert the screwdriver between the light cover and plastic sides and slowly move the screwdriver back and forth until the light cover becomes loose.
  4. 2008-2012 Honda Accord Interior Lights Replacement: passo 4, imagem 1 %32 2008-2012 Honda Accord Interior Lights Replacement: passo 4, imagem 2 %32
    • Turn the car off and wait until the light is cooled down before removal.
    • Use the flathead to help remove the light. Position the screwdriver between one end of the light and terminal.
    • Gently move the screwdriver downwards until the interior light detaches from the battery terminals.
  5. 2008-2012 Honda Accord Interior Lights Replacement: passo 5, imagem 1 %32
    • Slide one end of the replacement light against one terminal and push down delicately until the light is secure in place.
  6. 2008-2012 Honda Accord Interior Lights Replacement: passo 6, imagem 1 %32 2008-2012 Honda Accord Interior Lights Replacement: passo 6, imagem 2 %32
    • With the clips positioned upwards, move the plastic cover towards the light. Secure the cover back to its original position by applying a small force at the ends where the clips are.
  7. 2008-2012 Honda Accord Interior Lights Replacement: passo 7, imagem 1 %32
    • Turn on the light to verify funtionality.
    • Repeat steps 2-7 for the other light if necessary.
Conclusão
German Martinez
Membro desde: 10/24/23
145 Reputação
Autoria de 1 guia
Equipe
CSU Los Angeles, Team 9-8, Ribeiro Fall 2023 Membro de CSU Los Angeles, Team 9-8, Ribeiro Fall 2023
CSULA-RIBEIRO-F23S9G8
Membros da 3
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 21
Últimos 30 dias: 68
Duração total: 391
