Ir para o conteúdo principal
2008-2012 Honda Accord Headlight Bulb Replacement
O que você precisa
  1. 2008-2012 Honda Accord Headlight Bulb Replacement, Headlight Bulb: passo 1, imagem 1 %32
    • (Right Side Headlight)
    • Turn the wheel all the way inward to have enough clearance.
    • Turn the vehicle fully off before proceeding to the next step.
  2. 2008-2012 Honda Accord Headlight Bulb Replacement: passo 2, imagem 1 %32 2008-2012 Honda Accord Headlight Bulb Replacement: passo 2, imagem 2 %32 2008-2012 Honda Accord Headlight Bulb Replacement: passo 2, imagem 3 %32
    • Locate the inner fender's retainer clips.
    • Using a flat-head screwdriver, pry out the retainer clips.
  3. 2008-2012 Honda Accord Headlight Bulb Replacement: passo 3, imagem 1 %32
    • Pry back the inner fender liner to gain access to the headlight bulb.
    • An object may be needed to keep the fender liner pulled back
  4. 2008-2012 Honda Accord Headlight Bulb Replacement: passo 4, imagem 1 %32 2008-2012 Honda Accord Headlight Bulb Replacement: passo 4, imagem 2 %32 2008-2012 Honda Accord Headlight Bulb Replacement: passo 4, imagem 3 %32
    • Locate the headlight bulb, and turn the item clockwise so that it points towards the engine.
    • For the left bulb, turn the item counter clock-wise
  5. 2008-2012 Honda Accord Headlight Bulb Replacement: passo 5, imagem 1 %32 2008-2012 Honda Accord Headlight Bulb Replacement: passo 5, imagem 2 %32
    • Pull out the headlight bulb from its socket.
    • Be careful while pulling the bulb out, you might damage the bulb or its connected cable.
  6. 2008-2012 Honda Accord Headlight Bulb Replacement: passo 6, imagem 1 %32 2008-2012 Honda Accord Headlight Bulb Replacement: passo 6, imagem 2 %32 2008-2012 Honda Accord Headlight Bulb Replacement: passo 6, imagem 3 %32
    • For a more visible view of this step since the space is small and cluttered. -Credit for these 3 pictures: @PrecisionLED
    • To disconnect the bulb, pinch the top of the white block to release it from the bulb
    • When installing a new bulb, be careful while handling the bulb to not smudge or damage the bulb.
Conclusão
Carson Nguyen
Membro desde: 10/23/23
133 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 17
Últimos 7 dias: 115
Últimos 30 dias: 442
Duração total: 2,829
