Ir para o conteúdo principal
2008-2013 Subaru Forester Engine Air Intake Filter Replacement
O que você precisa
  1. 2008-2013 Subaru Forester Engine Air Intake Filter Replacement, Engine Air Intake Filter: passo 1, imagem 1 %32 2008-2013 Subaru Forester Engine Air Intake Filter Replacement, Engine Air Intake Filter: passo 1, imagem 2 %32
    • Make sure that the vehicle is turned off before you start.
    • Pull the hood release latch under the driver's dashboard to unlock the hood.
    • Press on the latch under the hood to expose the engine.
  2. 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: passo 2, imagem 1 %32 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: passo 2, imagem 2 %32
    • Locate the engine air intake holding and hose.
  3. 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: passo 3, imagem 1 %32 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: passo 3, imagem 2 %32
    • Unclip and separate the sensor and sensor cable on top of the holding.
    • Move the sensor cable to the side to prevent it from getting in the way.
  4. 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: passo 4, imagem 1 %32 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: passo 4, imagem 2 %32
    • Unlatch the metal clips keeping the holding together.
  5. 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: passo 5, imagem 1 %32 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: passo 5, imagem 2 %32
    • Use a 1/4" flat screwdriver to loosen the metal hose fastener on the engine air intake hose.
    • Do not remove the metal hose fastener. Keep the fastener on the hose for easy reassembly.
    • Remove the engine air intake hose from the holding.
    • Move the engine air intake hose to the side to prevent it from getting in the way.
  6. 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: passo 6, imagem 1 %32 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: passo 6, imagem 2 %32
    • Separate the two sides of the holding from each other.
    • Remove the back panel of the holding to add space to remove the engine air filter.
  7. 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: passo 7, imagem 1 %32 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: passo 7, imagem 2 %32
    • Remove the old engine air intake filter from the holding.
    • Insert the new engine air intake filter into the holding in the same position as the old filter.
Conclusão
Julianna Sober
Membro desde: 09/29/21
145 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 15
Últimos 30 dias: 78
Duração total: 2,626
