Ir para o conteúdo principal
2007 Honda CR-V Brake Light Replacement
O que você precisa
  1. 2007 Honda CR-V Brake Light Replacement, Brake Light: passo 1, imagem 1 %32 2007 Honda CR-V Brake Light Replacement, Brake Light: passo 1, imagem 2 %32 2007 Honda CR-V Brake Light Replacement, Brake Light: passo 1, imagem 3 %32
    • Grab the handle in the middle of the trunk.
    • Use the handle to pull the trunk open.
  2. 2007 Honda CR-V Brake Light Replacement: passo 2, imagem 1 %32 2007 Honda CR-V Brake Light Replacement: passo 2, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove the top and bottom screws.
  3. 2007 Honda CR-V Brake Light Replacement: passo 3, imagem 1 %32 2007 Honda CR-V Brake Light Replacement: passo 3, imagem 2 %32
    • Pull back the tail light cover.
    • Hold it up; there are cords connected to the car inside.
  4. 2007 Honda CR-V Brake Light Replacement: passo 4, imagem 1 %32 2007 Honda CR-V Brake Light Replacement: passo 4, imagem 2 %32 2007 Honda CR-V Brake Light Replacement: passo 4, imagem 3 %32
    • Untwist the faulty bulb counter-clockwise.
    • Pull the bulb out of the socket.
  5. 2007 Honda CR-V Brake Light Replacement: passo 5, imagem 1 %32 2007 Honda CR-V Brake Light Replacement: passo 5, imagem 2 %32
    • Disconnect the bulb from the cord by popping it off.
  6. 2007 Honda CR-V Brake Light Replacement: passo 6, imagem 1 %32 2007 Honda CR-V Brake Light Replacement: passo 6, imagem 2 %32
    • Pop in the Sylvania LongLife Mini Bulb 7443LL.
  7. 2007 Honda CR-V Brake Light Replacement: passo 7, imagem 1 %32 2007 Honda CR-V Brake Light Replacement: passo 7, imagem 2 %32 2007 Honda CR-V Brake Light Replacement: passo 7, imagem 3 %32
    • Insert the bulb into the socket.
    • Twist the bulb in clockwise.
  8. 2007 Honda CR-V Brake Light Replacement: passo 8, imagem 1 %32 2007 Honda CR-V Brake Light Replacement: passo 8, imagem 2 %32
    • Set the tail light cover back to the default position over the screw holes.
  9. 2007 Honda CR-V Brake Light Replacement: passo 9, imagem 1 %32 2007 Honda CR-V Brake Light Replacement: passo 9, imagem 2 %32
    • Use a Phillips #00 screwdriver to screw in the top and bottom screws.
Linha de Chegada
Dillon Laney
Membro desde: 02/21/23
169 Reputação
Autoria de 1 guia
Um comentário
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 31
Últimos 30 dias: 133
Duração total: 1,078
