Ir para o conteúdo principal
2007 Honda Accord Bass Speakers Replacement
O que você precisa
  1. 2007 Honda Accord Bass Speakers Replacement, Bass Speakers: passo 1, imagem 1 %32 2007 Honda Accord Bass Speakers Replacement, Bass Speakers: passo 1, imagem 2 %32 2007 Honda Accord Bass Speakers Replacement, Bass Speakers: passo 1, imagem 3 %32
    • Use the plastic opening tools to remove the floor trim panel on the driver's side door.
  2. 2007 Honda Accord Bass Speakers Replacement: passo 2, imagem 1 %32 2007 Honda Accord Bass Speakers Replacement: passo 2, imagem 2 %32 2007 Honda Accord Bass Speakers Replacement: passo 2, imagem 3 %32
    • Remove the shifter frame panel with the same opening tools.
  3. 2007 Honda Accord Bass Speakers Replacement: passo 3, imagem 1 %32 2007 Honda Accord Bass Speakers Replacement: passo 3, imagem 2 %32 2007 Honda Accord Bass Speakers Replacement: passo 3, imagem 3 %32
    • Unclip the heated seats harnesses.
    • Remove the 12V power supply connection.
  4. 2007 Honda Accord Bass Speakers Replacement: passo 4, imagem 1 %32 2007 Honda Accord Bass Speakers Replacement: passo 4, imagem 2 %32 2007 Honda Accord Bass Speakers Replacement: passo 4, imagem 3 %32
    • Remove the cubby space to access the head unit.
  5. 2007 Honda Accord Bass Speakers Replacement: passo 5, imagem 1 %32 2007 Honda Accord Bass Speakers Replacement: passo 5, imagem 2 %32
    • Remove the center climate vents with the opening tools.
  6. 2007 Honda Accord Bass Speakers Replacement: passo 6, imagem 1 %32 2007 Honda Accord Bass Speakers Replacement: passo 6, imagem 2 %32 2007 Honda Accord Bass Speakers Replacement: passo 6, imagem 3 %32
    • Remove the head unit from the dash.
  7. 2007 Honda Accord Bass Speakers Replacement: passo 7, imagem 1 %32 2007 Honda Accord Bass Speakers Replacement: passo 7, imagem 2 %32 2007 Honda Accord Bass Speakers Replacement: passo 7, imagem 3 %32
    • Attach the wiring harness into the amp by clipping it in.
  8. 2007 Honda Accord Bass Speakers Replacement: passo 8, imagem 1 %32 2007 Honda Accord Bass Speakers Replacement: passo 8, imagem 2 %32 2007 Honda Accord Bass Speakers Replacement: passo 8, imagem 3 %32
    • Run the wires under the back seat and along the driver's side door sill (removed in step 1) to under the steering wheel.
  9. 2007 Honda Accord Bass Speakers Replacement: passo 9, imagem 1 %32 2007 Honda Accord Bass Speakers Replacement: passo 9, imagem 2 %32 2007 Honda Accord Bass Speakers Replacement: passo 9, imagem 3 %32
    • Drill a hole through the firewall located on the foot well of the driver's side under the steering wheel.
  10. 2007 Honda Accord Bass Speakers Replacement: passo 10, imagem 1 %32 2007 Honda Accord Bass Speakers Replacement: passo 10, imagem 2 %32 2007 Honda Accord Bass Speakers Replacement: passo 10, imagem 3 %32
    • Run the power and ground wires from the trunk through the door sill and through the firewall to the engine bay.
  11. 2007 Honda Accord Bass Speakers Replacement: passo 11, imagem 1 %32 2007 Honda Accord Bass Speakers Replacement: passo 11, imagem 2 %32 2007 Honda Accord Bass Speakers Replacement: passo 11, imagem 3 %32
    • Run the power wire where it will be out of the way.
    • Run the power wire (red) and the ground wire (green) to battery, connect red to positive and green ground to a clean piece of the car body.
    • Make sure to leave the power wire off until finished.
  12. 2007 Honda Accord Bass Speakers Replacement: passo 12, imagem 1 %32 2007 Honda Accord Bass Speakers Replacement: passo 12, imagem 2 %32 2007 Honda Accord Bass Speakers Replacement: passo 12, imagem 3 %32
    • Remove the wiring harness from the back of the head unit.
    • Connect the four speaker wires and one remote wire to the harness as suggested in the owner's manual.
  13. 2007 Honda Accord Bass Speakers Replacement: passo 13, imagem 1 %32 2007 Honda Accord Bass Speakers Replacement: passo 13, imagem 2 %32 2007 Honda Accord Bass Speakers Replacement: passo 13, imagem 3 %32
    • Clamp down the wire harness on the five wires.
    • Tape up the wire loom to keep it neat.
    • Insert the wire harness back into the head unit.
  14. 2007 Honda Accord Bass Speakers Replacement: passo 14, imagem 1 %32 2007 Honda Accord Bass Speakers Replacement: passo 14, imagem 2 %32 2007 Honda Accord Bass Speakers Replacement: passo 14, imagem 3 %32
    • Put the head unit and the panels back into the car.
Conclusão
To reassemble your device, follow the instructions in reverse order.
Frankie
Membro desde: 03/24/21
253 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 19
Últimos 30 dias: 75
Duração total: 2,614
