Ir para o conteúdo principal
2007-2011 Toyota Camry Headlight Bulb Replacement
  1. 2007-2011 Toyota Camry Headlight Bulb Replacement, Headlight Bulb: passo 1, imagem 1 %32 2007-2011 Toyota Camry Headlight Bulb Replacement, Headlight Bulb: passo 1, imagem 2 %32
    • Pop up the hood of the car.
  2. 2007-2011 Toyota Camry Headlight Bulb Replacement: passo 2, imagem 1 %32 2007-2011 Toyota Camry Headlight Bulb Replacement: passo 2, imagem 2 %32
    • Locate the headlight bulb on the inside of the hood and hold onto the bulb.
    • The other headlight bulb is in the same area on the other side of the car.
  3. 2007-2011 Toyota Camry Headlight Bulb Replacement: passo 3, imagem 1 %32 2007-2011 Toyota Camry Headlight Bulb Replacement: passo 3, imagem 2 %32
    • Turn counterclockwise (1/4 of a turn) to remove the bulb and its attached plug from the socket.
    • This step is applied for both headlight bulbs.
  4. 2007-2011 Toyota Camry Headlight Bulb Replacement: passo 4, imagem 1 %32 2007-2011 Toyota Camry Headlight Bulb Replacement: passo 4, imagem 2 %32
    • Hold onto the bulb with one hand while holding down the clip at the bottom of the plug to remove the bulb.
  5. 2007-2011 Toyota Camry Headlight Bulb Replacement: passo 5, imagem 1 %32 2007-2011 Toyota Camry Headlight Bulb Replacement: passo 5, imagem 2 %32
    • Remove the new bulb from its package.
    • Make sure to not touch the glass part with your hands. This can cause a hot spot on the bulb, making it burn out faster. Wipe the bulb with a paper towel if contact was made.
  6. 2007-2011 Toyota Camry Headlight Bulb Replacement: passo 6, imagem 1 %32 2007-2011 Toyota Camry Headlight Bulb Replacement: passo 6, imagem 2 %32
    • Place the bulb back into the plug and press down until it click into place.
    • The bulb only goes in one way. Make sure the plug and the bulb are facing the same direction.
Conclusão
3 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 11
Últimos 7 dias: 59
Últimos 30 dias: 254
Duração total: 13,243
