Ir para o conteúdo principal
2007-2011 Honda CRV Stereo Replacement
O que você precisa
  1. 2007-2011 Honda CRV Stereo Replacement, 2011 Honda CRV Radio: passo 1, imagem 1 %32
    • Use caution, make sure your car is completely powered off and in park before you begin the repair. Do not have the key in the ignition.
    • Find the radio panel, also known as the automotive head unit, positioned centrally on the dashboard.
  2. 2007-2011 Honda CRV Stereo Replacement: passo 2, imagem 1 %32 2007-2011 Honda CRV Stereo Replacement: passo 2, imagem 2 %32 2007-2011 Honda CRV Stereo Replacement: passo 2, imagem 3 %32
    • Use a trim removal tool to loosen and pry the AC control until it detaches from the dashboard.
  3. 2007-2011 Honda CRV Stereo Replacement: passo 3, imagem 1 %32 2007-2011 Honda CRV Stereo Replacement: passo 3, imagem 2 %32 2007-2011 Honda CRV Stereo Replacement: passo 3, imagem 3 %32
    • Use your hands to pull the AC control forward and pop it out.
    • Even when loosened, the AC control may be difficult to pull out and remove. Do not be afraid to use force to remove it from the dashboard.
  4. 2007-2011 Honda CRV Stereo Replacement: passo 4, imagem 1 %32 2007-2011 Honda CRV Stereo Replacement: passo 4, imagem 2 %32 2007-2011 Honda CRV Stereo Replacement: passo 4, imagem 3 %32
    • With the AC control out, push down on the connector tab to release the AC cable at the back of the unit.
    • Don't pull on the cable itself and don't yank the cable as excessive force may cause damage.
  5. 2007-2011 Honda CRV Stereo Replacement: passo 5, imagem 1 %32 2007-2011 Honda CRV Stereo Replacement: passo 5, imagem 2 %32 2007-2011 Honda CRV Stereo Replacement: passo 5, imagem 3 %32
    • Use a trim removal tool to pop out the top panel above the AC vents.
    • Start in the top middle section to loosen it.
    • There is a small opening where you can place the trim tool to get started.
  6. 2007-2011 Honda CRV Stereo Replacement: passo 6, imagem 1 %32 2007-2011 Honda CRV Stereo Replacement: passo 6, imagem 2 %32 2007-2011 Honda CRV Stereo Replacement: passo 6, imagem 3 %32
    • Use a trim removal tool to pry open the AC vent.
    • Insert the tool along the bottom and sides of the vents, gently prying until it becomes loose.
  7. 2007-2011 Honda CRV Stereo Replacement: passo 7, imagem 1 %32 2007-2011 Honda CRV Stereo Replacement: passo 7, imagem 2 %32 2007-2011 Honda CRV Stereo Replacement: passo 7, imagem 3 %32
    • Pull the vents towards you from the sides.
    • The vent unit should pop out easily once it is loosened. Put it up on the dash board and out of the way.
  8. 2007-2011 Honda CRV Stereo Replacement: passo 8, imagem 1 %32 2007-2011 Honda CRV Stereo Replacement: passo 8, imagem 2 %32 2007-2011 Honda CRV Stereo Replacement: passo 8, imagem 3 %32
    • Use Phillips #2 screwdriver to remove the top two 12 mm screws.
  9. 2007-2011 Honda CRV Stereo Replacement: passo 9, imagem 1 %32 2007-2011 Honda CRV Stereo Replacement: passo 9, imagem 2 %32 2007-2011 Honda CRV Stereo Replacement: passo 9, imagem 3 %32
    • Use Phillips #2 screwdriver to remove the two 12 mm screws below the radio unit.
  10. 2007-2011 Honda CRV Stereo Replacement: passo 10, imagem 1 %32 2007-2011 Honda CRV Stereo Replacement: passo 10, imagem 2 %32 2007-2011 Honda CRV Stereo Replacement: passo 10, imagem 3 %32
    • Wiggle and pull the radio unit forward until it is freed from the dashboard.
  11. 2007-2011 Honda CRV Stereo Replacement: passo 11, imagem 1 %32 2007-2011 Honda CRV Stereo Replacement: passo 11, imagem 2 %32 2007-2011 Honda CRV Stereo Replacement: passo 11, imagem 3 %32
    • Press on the three cable connector tabs to release them from their sockets and remove the three gray cables from the back of the radio unit.
    • Use caution to avoid excessively stressing exposed cables during removal, making sure to exert force only on the plastic removal tabs.
  12. 2007-2011 Honda CRV Stereo Replacement: passo 12, imagem 1 %32 2007-2011 Honda CRV Stereo Replacement: passo 12, imagem 2 %32
    • Remove the car stereo from the dashboard.
Conclusão
Christa Day
Membro desde: 02/26/24
205 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 17
Últimos 30 dias: 87
Duração total: 171
