Ir para o conteúdo principal
2007-2012 Jeep Wrangler Air Filter Replacement
  1. 2007-2012 Jeep Wrangler Air Filter Replacement, How to open the 2007-2012 Jeep Wrangler hood: passo 1, imagem 1 %32 2007-2012 Jeep Wrangler Air Filter Replacement, How to open the 2007-2012 Jeep Wrangler hood: passo 1, imagem 2 %32
    • Locate the two grey latches on each side of the hood near the headlights.
    • Pull the latches away from the hood to release the latches.
  2. 2007-2012 Jeep Wrangler Air Filter Replacement: passo 2, imagem 1 %32 2007-2012 Jeep Wrangler Air Filter Replacement: passo 2, imagem 2 %32
    • Reach underneath the hood and push up on the lever located in the front center of the hood. You can now open the hood.
    • Prop the hood open by inserting the hood support rod into the designated hole on the underside of the hood.
  3. 2007-2012 Jeep Wrangler Air Filter Replacement, Air Filter: passo 3, imagem 1 %32 2007-2012 Jeep Wrangler Air Filter Replacement, Air Filter: passo 3, imagem 2 %32
    • Locate the air filter box in front of the car battery. It will have a 4-inch diameter hose coming out of one side (towards the center of the vehicle) and an air release coming out of the other side. It should have four clamps keeping it sealed.
  4. 2007-2012 Jeep Wrangler Air Filter Replacement: passo 4, imagem 1 %32 2007-2012 Jeep Wrangler Air Filter Replacement: passo 4, imagem 2 %32 2007-2012 Jeep Wrangler Air Filter Replacement: passo 4, imagem 3 %32
    • Locate the four clips keeping the air filter box sealed. Their locations are as follows:
    • Back Left Corner (near the outer edge of the hood) [picture 1]
    • Front Left Corner (near the outer edge of the hood) [picture 1]
    • Back Right Corner (underneath the four-inch diameter hose) [picture 2]
    • Bottom Right Corner (near the steering fluid container in the front) [picture 3]
  5. 2007-2012 Jeep Wrangler Air Filter Replacement: passo 5, imagem 1 %32
    • To unlock the air filter box, grasp each clip and pull the clip away from the air filter box.
  6. 2007-2012 Jeep Wrangler Air Filter Replacement: passo 6, imagem 1 %32 2007-2012 Jeep Wrangler Air Filter Replacement: passo 6, imagem 2 %32
    • After you have removed the 4 clips, carefully pull and twist the cover off. You now have access to the air filter.
  7. 2007-2012 Jeep Wrangler Air Filter Replacement: passo 7, imagem 1 %32 2007-2012 Jeep Wrangler Air Filter Replacement: passo 7, imagem 2 %32
    • Remove the dirty air filter by pulling the air filter straight up. Place the new replacement filter in the empty slot.
    • Refer to any labels on the filter about usage.
Conclusão
Adam Donald
Membro desde: 09/26/12
299 Reputação
4 Guias de autoria
Equipe
Cal Poly, Team 7-51, Forte Fall 2012 Membro de Cal Poly, Team 7-51, Forte Fall 2012
CPSU-FORTE-F12S7G51
5 Membros
9 Guias de autoria
2 comentários
I couldn't get the housing unit off. :(
David J - Responder
You forgot to add the step about removing the two bolts from the air intake assembly. You can't lift the housing unit off unless you remove the bolts.
lahacade - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 54
Duração total: 9,760
