Ir para o conteúdo principal
2007-2012 Acura RDX Engine Air Filter Replacement
O que você precisa
  1. 2007-2012 Acura RDX Engine Air Filter Replacement, Engine Air Filter: passo 1, imagem 1 %32
    • On the driver-side footwell, pull the latch to open the hood.
    • Make sure you leave time between driving and performing this fix. Working around the engine while it is still hot presents a burn risk!
  2. 2007-2012 Acura RDX Engine Air Filter Replacement: passo 2, imagem 1 %32
    • Lift up the second latch to fully open the hood.
    • This one is located right above the Acura logo on the front of the car.
  3. 2007-2012 Acura RDX Engine Air Filter Replacement: passo 3, imagem 1 %32
    • The airbox is directly behind the battery. Remove the four 9 mm bolts holding the airbox down.
    • If you ever had the bolts replaced, they may have a slightly different head diameter. If a 9 mm socket doesn't fit, use the appropriate size socket.
  4. 2007-2012 Acura RDX Engine Air Filter Replacement: passo 4, imagem 1 %32
    • Unscrew each of the bolts. Do not remove the bolts.
    • If the bolts are stuck, use some WD-40 or similar lubricant to help loosen them.
  5. 2007-2012 Acura RDX Engine Air Filter Replacement: passo 5, imagem 1 %32 2007-2012 Acura RDX Engine Air Filter Replacement: passo 5, imagem 2 %32
    • Remove the air filter from the vehicle.
    • In many cases, air filters will have an arrow to show the direction they should go. This direction represents the airflow, for this particular car we want that facing upwards.
    • Do not fully remove the bolts.
Conclusão
One the task is done, close the hood and you are good to drive!
Uma outra pessoa concluiu este guia.
Andrew Graham
Membro desde: 03/23/21
145 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 21
Últimos 30 dias: 118
Ao todo: 2,695
