Introdução
If your turn signal lights aren't responding when you use the turn signal ignition, it may be a sign that you need to replace the light bulb for your signal lights. Signal lights are an important feature of cars, as they provide security for the driver and others around them. While they are proven to last long, it can be expensive to replace if done by a professional.
In this guide, you will find a step by step guide detailing the process of repairing and/or changing signal lights in the 2006 Toyota Tacoma, requiring little to no experience on the subject.
O que você precisa
Turn on the car, and switch the signal light ignition, so that both lights turn on.
