Introdução
This guide will show you how to replace the side view mirror of a 2006 Toyota Highlander, though it will also work for 2000- 2007 models as well as any hybrid variants. Because of the way the mirror is connected to the car, this guide will show you how to take off the entire door panel in addition to the steps involving the mirror itself.
O que você precisa
Ferramenta utilizada nesse passo:Heavy-Duty Spudger$4.99
Pop out the master switch panel with a heavy duty spudger by sliding it in from the side.
Flip the master switch over to see the plug.
Unplug the master switch panel by firmly pushing down the notch and pulling it out.
To reassemble your device, follow these instructions in reverse order. The reminder bullet points will notify you if any special actions are required for reassembly.
