Ir para o conteúdo principal
2006 Kia Spectra Battery Replacement
O que você precisa
  1. 2006 Kia Spectra Battery Replacement, Battery: passo 1, imagem 1 %32
    • Turn the car off.
  2. 2006 Kia Spectra Battery Replacement: passo 2, imagem 1 %32 2006 Kia Spectra Battery Replacement: passo 2, imagem 2 %32
    • Locate the hood release lever near the lower left side of the steering wheel. Pop the hood by lifting up on the release lever.
  3. 2006 Kia Spectra Battery Replacement: passo 3, imagem 1 %32 2006 Kia Spectra Battery Replacement: passo 3, imagem 2 %32 2006 Kia Spectra Battery Replacement: passo 3, imagem 3 %32
    • Remove the positive (red circle) cable from the battery using the wrench to loosen the nut and bolt.
    • Then, remove the negative (orange circle) cable battery, using the wrench to loosen the nut and bolt.
  4. 2006 Kia Spectra Battery Replacement: passo 4, imagem 1 %32 2006 Kia Spectra Battery Replacement: passo 4, imagem 2 %32
    • Take the battery out, lifting the battery.
    • The battery will be heavy.
  5. 2006 Kia Spectra Battery Replacement: passo 5, imagem 1 %32
    • Clean the new battery with a rag to make sure it is ready to go.
  6. 2006 Kia Spectra Battery Replacement: passo 6, imagem 1 %32 2006 Kia Spectra Battery Replacement: passo 6, imagem 2 %32 2006 Kia Spectra Battery Replacement: passo 6, imagem 3 %32
    • Place the new battery in the base where the battery goes.
  7. 2006 Kia Spectra Battery Replacement: passo 7, imagem 1 %32 2006 Kia Spectra Battery Replacement: passo 7, imagem 2 %32
    • Attach the positive (red cirlce) cable to the battery by screwing on the nut and bolt with the wrench.
  8. 2006 Kia Spectra Battery Replacement: passo 8, imagem 1 %32 2006 Kia Spectra Battery Replacement: passo 8, imagem 2 %32 2006 Kia Spectra Battery Replacement: passo 8, imagem 3 %32
    • Then, attach the negative (red arrow) cable to the battery by screwing on the nut and bolt with the wench.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 52
Duração total: 4,841
