Ir para o conteúdo principal
2006 Iron Horse Warrior Rear Wheel Replacement
  1. 2006 Iron Horse Warrior Rear Wheel Replacement, Rear Wheel: passo 1, imagem 1 %32 2006 Iron Horse Warrior Rear Wheel Replacement, Rear Wheel: passo 1, imagem 2 %32
    • Turn the bike upside down if you don't have a bike stand. This will make it easier to remove the tire.
    • Unfasten the left side of the wheel by pulling the black "L" shaped lever up with your hands.
  2. 2006 Iron Horse Warrior Rear Wheel Replacement: passo 2, imagem 1 %32 2006 Iron Horse Warrior Rear Wheel Replacement: passo 2, imagem 2 %32
    • On the right side, use your hands to unscrew the cap of the axle counterclockwise until it is loose.
  3. 2006 Iron Horse Warrior Rear Wheel Replacement: passo 3, imagem 1 %32 2006 Iron Horse Warrior Rear Wheel Replacement: passo 3, imagem 2 %32
    • Push down on the the tire with your hands to remove it from the frame of the bike.
    • Sometimes the axle will get caught in the boxed area. Use both of your hands to cautiously push it down harder until the tire comes loose. This may require a fair amount of force.
Conclusão
Matt Halvorson
Membro desde: 04/21/15
354 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 15-2, Amido Spring 2015 Membro de Cal Poly, Team 15-2, Amido Spring 2015
CPSU-AMIDO-S15S15G2
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 12
Duração total: 1,047
