Ir para o conteúdo principal
2006 Honda Shadow Spirit 750 Battery Replacement
O que você precisa
  1. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove outer casing: passo 1, imagem 1 %32
    • Remove the plastic covering, located on the left side of the bike, by pulling the piece straight off the bike.
  2. 2006 Honda Shadow Spirit 750 Battery Replacement, Open toolbox: passo 2, imagem 1 %32 2006 Honda Shadow Spirit 750 Battery Replacement, Open toolbox: passo 2, imagem 2 %32 2006 Honda Shadow Spirit 750 Battery Replacement, Open toolbox: passo 2, imagem 3 %32
    • The tool box is located under the panel.
    • Using the key to the motorbike, unlock the tool box.
    • Remove the plastic bag inside holding the tools needed for basic maintenance for the motorbike.
  3. 2006 Honda Shadow Spirit 750 Battery Replacement, Unscrew the seat: passo 3, imagem 1 %32 2006 Honda Shadow Spirit 750 Battery Replacement, Unscrew the seat: passo 3, imagem 2 %32
    • Using the allen wrench, remove the screws on both sides of the bike seat.
  4. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove the seat: passo 4, imagem 1 %32
    • Pull the rear of the seat upwards.
    • Pull the seat backwards to remove it from the bike.
  5. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove plastic covering: passo 5, imagem 1 %32
    • Using the screwdriver, remove the screw holding the plastic cover.
  6. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove the fusebox: passo 6, imagem 1 %32
    • Pull the cover off the battery and remove the fuse box from the cover.
    • Place the fuse box over to the side right of the bike. Do not disconnect the wires.
  7. 2006 Honda Shadow Spirit 750 Battery Replacement, Detach the ground wire: passo 7, imagem 1 %32
    • Using the screwdriver, remove the ground wire (negative (-) cable) from the battery.
    • Place the wire over the left side of the bike.
  8. 2006 Honda Shadow Spirit 750 Battery Replacement, Detach the power cable: passo 8, imagem 1 %32
    • Also using the screwdriver, remove the positive (+) cable from the battery.
    • Place the wire over the right side of the bike.
    • Do not let the red(+) and black(-) wires touch
  9. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove the battery: passo 9, imagem 1 %32
    • Remove the battery from the bike by pulling upwards.
Conclusão
9 outras pessoas executaram este guia.
Dazarene Cascio
Membro desde: 10/07/14
736 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 1-7, Donnelly Fall 2014 Membro de USF Tampa, Team 1-7, Donnelly Fall 2014
USFT-DONNELLY-F14S1G7
1 Membro
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 24
Últimos 30 dias: 98
Duração total: 18,840
