Ir para o conteúdo principal
2006 Dodge RAM Turn Signal Bulb Replacement
O que você precisa
  1. 2006 Dodge RAM Turn Signal Bulb Replacement, Turn Signal Bulb: passo 1, imagem 1 %32 2006 Dodge RAM Turn Signal Bulb Replacement, Turn Signal Bulb: passo 1, imagem 2 %32 2006 Dodge RAM Turn Signal Bulb Replacement, Turn Signal Bulb: passo 1, imagem 3 %32
    • Remove the two screws securing the light to the truck using an Allen wrench.
  2. 2006 Dodge RAM Turn Signal Bulb Replacement: passo 2, imagem 1 %32 2006 Dodge RAM Turn Signal Bulb Replacement: passo 2, imagem 2 %32 2006 Dodge RAM Turn Signal Bulb Replacement: passo 2, imagem 3 %32
    • Pull the light casing out of the socket.
    • The wires exposed at the back of the light case are dangerous to touch as they are exposed electrical wires. Do not interact with them.
  3. 2006 Dodge RAM Turn Signal Bulb Replacement: passo 3, imagem 1 %32 2006 Dodge RAM Turn Signal Bulb Replacement: passo 3, imagem 2 %32 2006 Dodge RAM Turn Signal Bulb Replacement: passo 3, imagem 3 %32
    • Remove the four screws from the light case.
  4. 2006 Dodge RAM Turn Signal Bulb Replacement: passo 4, imagem 1 %32 2006 Dodge RAM Turn Signal Bulb Replacement: passo 4, imagem 2 %32 2006 Dodge RAM Turn Signal Bulb Replacement: passo 4, imagem 3 %32
    • Remove the light case from the light bulb holders.
  5. 2006 Dodge RAM Turn Signal Bulb Replacement: passo 5, imagem 1 %32 2006 Dodge RAM Turn Signal Bulb Replacement: passo 5, imagem 2 %32 2006 Dodge RAM Turn Signal Bulb Replacement: passo 5, imagem 3 %32
    • Replace the light bulb by gently pulling the original light bulb out.
    • Replace the lightbulb with a new one.
  6. 2006 Dodge RAM Turn Signal Bulb Replacement: passo 6, imagem 1 %32 2006 Dodge RAM Turn Signal Bulb Replacement: passo 6, imagem 2 %32 2006 Dodge RAM Turn Signal Bulb Replacement: passo 6, imagem 3 %32
    • Reattach the lightbulbs to the light casing and put the 4 screws back in.
    • Pop the light casing back into place by making sure the two pointed ends go into the holes.
    • Replace the two screws that secure the light to the truck using an Allen wrench.
Linha de Chegada
Eddie Echegoyen
Membro desde: 10/18/23
133 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 17
Duração total: 125
